Yass
Get month name so i can display it
I'd like to retrieve the current month's name to display it in my results.
I tried using this function but i get every time the current date in format dd/mm/yyyy  :
current_month = Format(Today(), "Mon");
textbox_result << Set Text(
        "ICT  NOK  %  for " || current_month || " is " || Char(Round(percent_nok_ict, 2)) || "%\!N" ||
        "FCT  NOK  %  for " || current_month || " is " || Char(Round(percent_nok_fct, 2)) || "%"
3 ACCEPTED SOLUTIONS
Re: Get month name so i can display it
You could use Format Pattern
opt1 = Format(Today(), "Format Pattern", "<Month>");
opt2 = Format(Today(), "Format Pattern", "<Mmm>");
show(opt1, opt2);
I'm not sure if << Use Locale(0) would work
opt1 = Format(Today(), "Format Pattern", "<Month>", << Use Locale(0));
If not you could create conversion list and use that
months = {"Jan", "Feb", "Mar", "Apr", "May", "Jun", "Jul", "Aug", "Sep", "Oct", "Nov", "Dec"};
months[Month(Today())];
Level XIII
If you use the English version of JMP, a very nasty workaround:
"use JMP language ..."
from the Preferences/Windows Settings.
It will interfere with dozens of other functions (csv import, date in data tables ....)
show(opt1, opt2);
Yass
That works perfectly, thank you !
I have a quick follow-up question. I successfully retrieved the month, but it's currently in French. Is there a function in JMP that can translate it to English ?
Level XIII
Yass
Thank you! Using Locale(0) worked perfectly.
