Paul06
Get column names that has particular value
I just started using jmp at work and trying to learn JSL. I am trying to write a script to get the column names where the row value =1. For example, the table shows values of 0 and 1 under different IMCX columns and I want to find out which column has the value =1 in each row and store under a new column called IMC. In the first row,  column IMC 4 has 1 so I manually enter IMC4 under IMC. There are more than 5000 rows in the tables. Thank you for the help.
10 REPLIES 10
Paul06
Re: Get column names that has particular value
Thanks you for your time and help. I am sorry I did not state the problem clearly. In each row, there is only one instance of 1 under a column and I need to pick out the column name and save under a new column.
