DanFromCA
Control Chart Labels
I recently upgraded to JMP 18 from JMP 14. I much prefer the format of legacy control charts where the UCL and Avg lines are labeled with their values just to the right of the graph. Is there a way to accomplish this with the new control charts, instead of that information being in a separate table? I have a decent knowledge of JMP scripts and used to be able to manipulate these labels in the legacy charts, but I can't find the right box now to even add them to.
Any suggestions?
Re: Control Chart Labels
Is this close to what you want?
DanFromCA
Thanks. The label used to be outside the frame, but this is close and I can make it work.
Thank you for your time to help.
Dan
