Samu
Get a jrp like script from a report window
Hello everyone,
I am trying to save my report script to a jrp file as explained in: Save charts as ".jrp" file in JSL
However, I don't have direct access to the Graph Builder that generated my Report Window.
I'm getting my reports via
Get Window List(Type("Reports"));
And now I need to extract the script to save it as a text file, however I can't figure out how to get that script.
When using << Get Script I only end up with things like
GraphBuilderBox(ScaleBox(ParallelScaleBox(ScaleBox(ScaleBox(ScaleBox(ScaleBox(ScaleBox(ScaleBox(GraphBuilderContainerBox(Graph[...]
How do I get a text that's more like
Graph Builder(
 Size( 1896, 975 ),
 Show Control Panel( 0 ),
 Show Legend( 0 ),
 Variables(...
Re: Get a jrp like script from a report window
The "Get Window List" returns the Top Parent for the window.
The "Get Scriptable Object" is a message to an Outline Box().  Therefore, this modification should get you what you want.
dis = Distribution( Continuous Distribution( Column( :height ) ) );
x = (Get Window List( Type( "Reports" ) )[1][Outline Box( 1 )] << get scriptable object());
x << get script;
8 REPLIES 8
Jeff_Perkinson
Take a look at the Get Scriptable Object() message. You can use that to get access to the platform (i.e., Graph Builder) in a report.
Open( "$SAMPLE_DATA/Big Class.jmp" );
biv = bivariate( y( :weight ), x( :height ) );
rbiv = biv << report;
bivobj = rbiv << Get Scriptable Object();
bivobj<<get script();
-Jeff
Samu
Thank you for the reply. However I didn't manage to solve my issue yet.
After opening an existing .jrp file, which in turn opens a data table and a report window, the following scripts:
wList = Get Window List(Type("Reports"));
print(wList[1] << report << Get Scriptable Object() << get script());
print(wList[1] << Get Scriptable Object() << get script());
will both result in
HeadBox(V List Box(Box(OutlineBox(H List Box(NoCloneBox(IfBox(H List Box(V List Box(H List Box(ButtonBox, ButtonBox, ButtonBox), BorderBox(V List Box(H List Box(PopupBox, Text Box("40 Columns")), V List [... etc.]
Not the kind of script I am looking for. This seems to be a special case, since I'm starting with an existing report window. What am I doing wrong?
Jeff_Perkinson
It could be that your messages in:
aren't being executed in the order you think they are.
Compare the results of these two:
Print( (rbiv << Get Scriptable Object()) << get script() );
Print( rbiv << Get Scriptable Object() << get script() );
-Jeff
Samu
Interesting. By doing it step by step like this:
rep =  wList[1] << report;
so = rep << Get Scriptable Object();
skr = so << get script();
Print( skr );
 I am now getting error messages that Object 'HeadBox' does not recognize the message 'report'; as well as Object 'HeadBox' does not recognize the message 'Get Scriptable Object'; if I cut the report message. So Get Window List(Type("Reports")); gets me a headbox that can only recognize Get Script, which in turn gives me the same old
I already learned something, but I'm still not there yet. How do I get the Scriptable Object of my window?
x << get script;
Samu
Thank you very much, that did it!
This little nugget should be in the JSL Cookbook!  Thanks @txnelson !  @DonMcCormack
Thanks @MikeD_Anderson! I agree, it would make a good addition.
