xxvvcczz
Get Row numbers ... where row just exists. That's all I want is just a list of rows in the table ie [1,2,3,4,5,6]
I've got this GUI and I've got rows that I made
What I'm doing is using a row state handler to detect when someone selects mapped shapes in a graph.
That shows which rows they actually selected.
Now I have 2 helper "map shapes" in that graph as well. when they select something in the primary graph I need to highlight it in the helper graphs as well.
So this is my code, and I want selected to be live updated to be 1 or 2 so I can follow it up with another few lines that say:
get helper_rows that have the same keyname as the selected rows and select them too so the user knows they are related and I can then get them for a subset that is in my next step.
so my plan:
1. get list of all rows in table there has to be a better way than this...
 all_rownums = subset_JMP_Master_Table << GetRowsWhere (:Name != -99999);
2. inside the row state handler: get selected rows
3. subtract the selected rows from the total row list? Get 2 lists: 1 that is selected rows, and the other that is rows that arent selected.
4. Assign selected flag as 1 or 2 to the selected column.
5. Lookup helper rows based on  keyname + selected column = 1
6. select the helper rows as well and subset the whole thing for next steps.
 subset_JMP_Master_Table << New Column( "selected",
 Numeric
 , Ordinal
 ,set each value(0)
//rows_in_subset_table = subset_JMP_Master_ Table << Select All Rows;
//show(rows_in_subset_table);
select_sync_rsh = subset_JMP_Master_Table << MakeRowStateHandler(
Function(
{a}
,if(
select_sync_script_on
,( //start doing things based on script
print(a);
r = subset_JMP_Master_Table << get selected rows;
Column(subset_JMP_Master_Table, "selected")[r] = 1;
q = subset_JMP_Master_Table << GetRowsWhere (:selected != 1);
Column(subset_JMP_Master_Table, "selected")[q] = 2;
)//end doing things based on script
)// end if
); //end function
xxvvcczz
Re: Get Row numbers ... where row just exists. That's all I want is just a list of rows in the table ie [1,2,3,4,5,6]
subset_JMP_Master_Table << New Column( "selected", Numeric, Ordinal, set each value( 0 ) );
fhg = N Rows( subset_JMP_Master_Table );
all_rownums = subset_JMP_Master_Table << GetRowsWhere( :Name != -99999 );
    Function(
        {a}
        If(
            (//start doing things based on script
            Print( a ) ;
            subset_JMP_Master_Table:selected << Set Each Value( 2 ) ; // just blanket set everything to 2
            curr_selected_rows = subset_JMP_Master_Table << get selected rows ; // get the selected rows
            subset_JMP_Master_Table:selected[curr_selected_rows] = 1 ; //update the selected rows to 1
        )// end if
    ); //end function
); //end row state handler
xxvvcczz
    Function(
        {a}
        If(
            Print( a ) ;
        )// end if
    ); //end function
I think you can get your rownum matrix with
subset_JMP_Master_Table=current data table();
all_rownums = index(1,nrows(subset_JMP_Master_Table));
pmroz
You can also use the syntax 1::n to produce a matrix:
b = 1::nrows(subset_JMP_Master_Table);
