dileepkr
Generating graph builder graphs in a for loop
I am building a JMP app to generate multiple graphs out of an xlsx workbook, let me give a bit of background on the architecture of my code.
1. Each graph comes out of a JSL script which contains a function that takes datatable as input and returns graph builder ref as output.
2. On top level, I have a for loop on the datatables I need graphs for and I construct a function call and execute EVAL(func_call) inside the for loop.
3. I am putting each of the graph in a tabbed page in a tab box.
The problem I am facing is, the for loop in the main function stops execution right after the first graph is generated through EVAL(func_call)
Could anyone please help me in understanding why for loop exits out of looping after 1st graph is generated and how to fix this?
Thanks in advance!
Dileep
Re: Generating graph builder graphs in a for loop
Is it possible that the variable used in your For() loop (i.e. I=1,i<=25,i++), is being used elsewhere in your JSL, and it is changing the index value?
dileepkr
Thank you so much, that solved my problem! I will be more aware of this in future :)
