doraemengs
Generate new column (string) with compose of the same ID in different rows and excluded duplicate string
I want to generate a new column that combines the strings in the same ID in different rows as the example table (I want column results). Thank you
ID
Ab
results
1
A2, B3
A2, B3, B56, C7, DR5
1
A2, B56, C7, DR5
1
DR5
2
A56, B9, C0, DQ89
A56, B9, C0, DQ89
2
A56, B9, C0, DQ89
2
DQ89
A56, B9, C0, DQ89
3
A2
A2, DR5
3
DR5
A2, DR5
3 A2, DR5
Re: Generate new column (string) with compose of the same ID in different rows and excluded duplicate string
Here is the formula I worked out.  Others may have better ways
curID = :ID;
theRows = Current Data Table() << get rows where( :ID == curID );
theArray = Associative Array( Words( Concat Items( :Ab[theRows] ), ", " ) );
Concat Items( theArray << get keys );
Level XI
