Bmllnn
General script for fit model with saving student residuals for different variables
I am trying to create a script that I can use every time with minimum work to do ANOVA and Chi-sq directly.
I started the script:
dt=Current Data Table();
dlg = Column Dialog(
			name = ColList( "Parameters", Min Col(1) ),
			subject = ColList( "Treatment", Min Col(1), MaxCol(1) ),
			Reffect = ColList( "Random", Min Col(0), MaxCol(2) )
// Stop if the user did not press 'OK'
If( dlg["Button"] != 1, Beep(); Throw());
name = dlg[ "name" ];
subject = dlg["subject"];
Reffect = dlg ["Reffect"];
show (name, subject, Reffect);
dt<<Fit Model(
	Y( name[1]),
	Effects( subject[1]),
	Random Effects( Reffect[1]),
	NoBounds( 1 ),
	Method( "REML" ),
	Emphasis( "Effect Leverage" ),
	Run(
		Profiler( 0 ),
		name[1] << {Summary of Fit( 1 ), Analysis of Variance( 0 ),
		Parameter Estimates( 1 ), Scaled Estimates( 0 ),
		Plot Actual by Predicted( 1 ), Plot Residual by Predicted( 1 ),
		Plot Studentized Residuals( 0 ), Plot Effect Leverage( 1 ),
		Plot Residual by Normal Quantiles( 0 ), Interaction Plots( 0 ), AICc( 0 ),
		Show VIF( 0 )}
obj << Studentized Residuals;
//obj << Close Window;
However, there is an issue to do the fit model. The fit model box open only with the Y.
on the Y most of the time I need to add more than 1 variable as well, so I will have more student residuals to save to be able to verify the outliers, then the normal distribuition and the equal variance.
Thanks for your help :)
Re: General script for fit model with saving student residuals for different variables
Try adjusting the code to add eval(eval expr(expr))).  There's a blog post here that explains a little about how this works.  Also, the way the column dialog window is set up allows multiple Ys to be selected.
Eval(Eval Expr(obj=dt<<Fit Model(
	Y( expr(name)),
	Effects( expr(subject)),
	Random Effects( expr(Reffect)),
	NoBounds( 1 ),
	Method( "REML" ),
	Run(
		Profiler( 0 ),
		Show VIF( 0 )}
	Y( expr(name)),
	NoBounds( 1 ),
	Method( "REML" ),
	Run(
		Profiler( 0 ),
		Show VIF( 0 )}
