Hi @Dennisbur,
The default calculation in JMP for Std Dev is the one with Bessel's correction. As emphasized by @Dan_Obermiller, this is the most frequent case as you're frequently in the situation where you have data from a sample (hopefully a representative one), but not from the entire population.
As you can see in the datatable I provided, it is quite simple to re-create the formula if you need it.
On a side note, I would highly recommend to format data otherwise : observations in rows, and parameters/factors in columns.
This way, your formula will be also easier to create and maintain.
Here is the formula you can use with a column named "Values" containing your data. You will only need the individual values for your observations in this column (the number of rows is automatically calculated with the function "N Row()") :
Root( Col Sum( (:Values - Col Mean( :Values )) ^ 2 ) / N Row() )
If your column is named differently, just change the ":Values" with ":Name" (Name being the name of your column).
Hope this will help you,
Victor GUILLER
Scientific Expertise Engineer
L'OrƩal - Data & Analytics
