jimq
Fractional factorial with 3-level factors
I have a product mix with three components I am trying to minimize while maximizing my response. I have one response and four continuous factors. 3 of the factors are components of the product and the fourth factor is the starting temperature of the test that yields the response.
I would like to perform a fractional factorial rather than the full factorial method. I want all four factors to have three levels but reduce the number of trials from 81. A Screening design only allows 2-level factors. A Taguchi design allows 3-level factors but doesn't seem to be the right modeling method for my project.
Can a 3x3x3x3 fractional factorial be done using JMP6 or JMP7 to do this?
louv
Staff (Retired)
Re: Fractional factorial with 3-level factors
If the three components as you mention are truly components in a formulation then I would simply use the Custom Design capability in JMP to set up a 4 factor design where the first three factors are mixture components and the 4th factor is a continuous factor = Temperature. Adding the interactions to the model and specifying some center points (N=3) the number of runs required would only be 15. By treating this as a two level design with center points you get your three levels as you desired.
In JMP5, the answer is YES, you can get a fractional factorial of a 3**4 design (so I assume later versions of JMP can do this also).
The fractional factorial you are interested in is indeed the Taguchi 9-run design or the Taguchi 27-run design. These are identical to a standard fractional factorial. No difference. Go ahead, use it without qualms.
I also point out that a central composite design (response surface design) often has better statistical properties than the fractional factorial of a 3**4, and usually involves fewer runs as well.
Message was edited by: Paige
louv
Staff (Retired)
jimq
Thank you Lou and Paige. I will try them out.
