Lourdes
Formula does not apply to the column
I have this table, and I want the average of the column EC(mS/cm) on the column next to it, group by name.
I used this formula yesterday but today it does not work when I apply it to the column.
If( Row() == Col Min( As Column( "EC (mS/cm)" ) << By( :Name ) ),
Col Mean( As Column( "EC (mS/cm)" ) << By( :Name ) ),
Thank you in advance!
Re: Formula does not apply to the column
If(Row() == Col Min("EC (mS/cm)"n, :Name),
	Col Mean("EC (mS/cm)"n, :Name)
Lourdes
It does not apply the formula
Is your formula supressed?
Lourdes
I used this one and it worked:
If(
   Row() == Col Min( Row(), :Name ),
       Col Mean( :"EC (mS/cm)", :Name ),
