hogi
Level XIII
Vector Columns?
How Can I create a pre-filled Col List Box with all the Vector Columns of the current data table?
Like << Modeling Type({"Continuous"}), but for modeling type Vector.
dt = Open( "$SAMPLE_DATA/Big Class Families.jmp" );
New Window( "Vector columns",
Col List Box(All, width( 250 ),<< Modeling Type({"Continuous"}) ),
Col List Box(All, width( 250 ),<< Modeling Type({"Vector"} ) ));
Seems to be an issue of All - which doesn't pick All  columns .
 is there a command All_even_the_Expressions ?
Re: Vector Columns?
Loop over the list of columns, get vector modeling types and use "" with col list box
dt = Open("$SAMPLE_DATA/Big Class Families.jmp");
nw = New Window("Vector columns",
	clb = Col List Box(dt, "", width(250), <<Modeling Type({"Vector"}))
vcols = Filter Each({colname}, dt << Get Column Names("String"), Column(dt, colname) << get modeling type == "Vector");
clb << Set Items(vcols);
hogi
Level XIII
Re: Vector Columns?
@jthi , many thanks for the nice workaround :)
@JMP: why ?!
