SpannerHead
Forming a Column Formula from an Associative Array
I looked but couldn't find a clear example.  I have a script that creates an associative array between pairs of columns in a table.  I now want to leverage that array to create a formula referencing both the value and the key.  How is this done?
For( i = 1, i <= N Items( SpecCols ), i++,
    key = Column( dt, SpecCols[i] );
    value = Column( dt, Char(SpecCols[i])||" Pass/Fail");
    assocArray[key] = value;
			dt << New Column( (Column( dt, SpecCols[i] ) << get name) || " Best",
				Set Property( "Notes", Notes ),
				Set Property( "Limits", Limits ),
				Formula(If(
	:RETEST == Col Minimum(
		If(
			Col Mean( value, :LOT, :WAFER, :RETEST ) ==
			Eval( Parse( value)),
			:RETEST
		:LOT,
		:WAFER,
		:SiteY,
		:SiteX
	Eval( Parse(key))
Slán
SpannerHead
Re: Forming a Column Formula from an Associative Array
Expression evaluation and in cases like this I like using Eval(Substitute())
aa = Associative Array();
aa["NPN1"] = "NPN2";
aa["PNP1"] = "PNP2";
aa["INM1"] = "INM2";
new_cols = {};
For Each({{key, val}}, aa,
	new_col = Eval(Substitute(
		Expr(dt << New Column(key ||" "|| val, Numeric, Continuous, Formula(
			_term1_ + _term2_
		Expr(_term1_), Name Expr(AsColumn(dt, key)),
		Expr(_term2_), Name Expr(AsColumn(dt, val))
	Insert Into(new_cols, (new_col << get name))
dt << Move Selected Columns(new_cols, To First);
