mallen810
Format Date Column
I am importing some sql data and it is bringing in the dates as data type Character and nominal model type (2017-11-01) and I am having an issue changing it to a workable date format such as (11/1/17). How do I reformat to this date type? I am attaching the data table for your review.
Re: Format Date Column
Here is how to easily do what you want
1. Right click on the column header for pack_date and select Column  Info
2. In the Column Info window, change the Data Type from Character to Numeric
3. Click on the down arrow for the format and go to Date and select "m/d/y"
4. Click on the down arrow for the Input Format and go to Date and select "y/m/d"
5. Click on OK
5. Click on OK
mallen810
Thanks for the quick response, worked perfectly.
Larry_Wang
how to copy the column property to into a script, I did exactly copy paste the script, but when I run the script, this pasted script doesn't work.
Here is the JSL
names default to here(1);
dt=current data table();
:pack_date << data type(numeric)<<informat("y/d/d")<<format("m/d/y");
and this is the JSL that JMP generated when I did the conversion interactively
// Change column info: pack_date
Data Table( "BallMillHistory" ):pack_date <<
Set Data Type(
	Numeric,
	Format( "y/m/d", 10 ),
	Input Format( "y/m/d" ),
	Format( "m/d/y", 12 )
) << Set Modeling Type( "None" );
