RobertDuckie
Running JMP on Windows on Arm?
I've bought a Surface Laptop w/ a Snapdragon X Elite chip and was wondering if it could run JMP under x86 emulation.
Re: Running JMP on Windows on Arm?
You don't mention what version of JMP you are using.  I can say that JMP 18 should run fine under emulation on your system.
Brian Corcoran
JMP Development
