The_Annie
Force Control Chart Limit at Zero
Hi.  I have some data that is bound on the lower end by zero.  Is there a way to force Jmp to make the lower control limit zero?
Thanks!
Re: Force Control Chart Limit at Zero
If you set the LCL to zero in the Control Limits Column Property, JMP will use that limit in charting.
Right click on the column header and select
      Column Properties=>Control Limits
The_Annie
Thankyou!  I knew it had to be in there somewhere.
