Isabel26
auto fill today's date into data table name
I need to save as data table to xlsx AND auto adding today's date. For example, file name will be "old name 3/8/2022.xlsx" if I run the script on 3/8/2022, and  "old name 3/9/2022.xlsx" if I run the script on 3/9/2022. This is easy to do in SAS, and I assume JMP will be similar. Not sure how to fix the code. thanks
Data Table( "old name" ) << Save( "C:\old name || Today().xlsx" );
Jeff_Perkinson
Re: auto fill today's date into data table name
You need to Format the date:
Format( Today(), "ddMonYYYY" );
Two things to note:
  1. You don't need Char() since Format() returns a character string.
  2. Avoid the formats that contain slashes (/) since they are used as directory delimiters.
-Jeff
ron_horne
Hi @Isabel26
perhaps this will work:
Data Table( "old name" ) << Save( "C:\old name "|| char (Today())||".xlsx" );
Isabel26
Thanks! But the date is not format in MM/DD/YYYY. It returns 3729589915.
Jeff_Perkinson
Two things to note:
-Jeff
Isabel26
Thank you! It worked perfectly.
