ARETI052
For Loops and Column Lists
I am intending to build a Graph Builder for visualizing different columns of data each time. The Graph Builder should be able to take whatever many inputs columns (as long as it's less than 8). I built an input GUI but I dont think the y-values are recorded. How can I correctly pass the selected Y column data to the graph builder? Thanks!
Level XIII
Re: For Loops and Column Lists
You could prepare your Variables first and then use insert into to put them into Graph builder.
MyGraph = Function ({yCol,xCol},{default local},
vars= 	Eval Expr(Variables(
		X( Expr(xCol) ),
		Group X( :Temperature )
	pts= Expr(Points( X));
	For(j = 1, j <= Min(8, N Items(yCol)), j++,
               Insert Into(vars, Eval Expr(Y( Expr(yCol[j]))));
	gb = Expr(
		Graph Builder(
	Insert Into(gb, Name Expr(vars));
	VListBox(gb)
Please use the txnelson_0-1719510632610.png icon to display your JSL.  It allows for the reader to test your code and provide responses.  Pasting in images of your code will not allow this, and therefore many possible responders will opt not to respond because of the time it would take to retype in your JSL
ARETI052
names Default To Here(1);
	vlb = VListBox(
		Graph Builder(
	Size( 1255, 981 ),
	Variables(
		X( Eval(xCol) ),
                Y( Eval(yCol[j]))  // Evaluate each yVar
	Elements( Points( X, Y( 1 ), Y( 2 ), Y( 3 ), Y( 4 ), Y( 5 ), Y( 6 ), Y( 7 ), Y( 8 ), Legend( 11 ) ) ),
	Local Data Filter(
		Add Filter(
			columns( :Test Stage, :Sublot, :Temperature, :Soft Bin ),
			Display( :Test Stage, N Items( 4 ) ),
			Display( :Soft Bin, N Items( 15 ) )
	return(vlb);
dt = CurrentDatatable();
nw = NewWindow("Column Selection", <<modal,
	<<onClose(
		lstX = clbX << getItems;
		lstY = clbY << getItems;
	BorderBox(top(10),bottom(10),left(10),right(10),
		VListBox(
			TextBox("Select X and Y variables"),
			HListBox(
				PanelBox("Select Columns",
					fcs = FilterColSelector()
				SpacerBox(size(10,0)),
				PanelBox("Cast Selected Columns into Roles",
					HListBox(
						ButtonBox("Y,Response",
							sel = fcs << getSelected;
							clbY << append(sel);
						SpacerBox(size(6,0)),
						clbY = CollistBox(numeric,maxitems(8),minitems(1),nlines(8))
					HListBox(
						ButtonBox("X,Variable",
							clbX << append(sel);
						clbX = CollistBox(maxitems(2),minitems(1),nlines(2))
if (nw["Button"]==-1,throw());
if (Nitems(lstX)==0,throw());
if (Nitems(lstY)==0,throw());
yColName = lstY;
xColName = lstX;
show(lstY,lstX);
NewWindow("My report",
	VListBox(
		MyGraph(yColName,xColName),
		HCenterBox(
		btn = ButtonBox("show distribution")
btn << setScript(
MyHistograms()
ARETI052
Thanks for the advice, here is my full script.
ARETI052
The embedded log is showing "Specified Column not found in data table. in access or evaluation of 'For' , For/*###*/(j = 1, j <= Min( 8, N Items( yCol ) ), j++, Y( Eval( yCol[j] ) ))"
But I used the column is clearly in my data table.
Level XIII
		X( Expr(xCol) ),
	gb = Expr(
		Graph Builder(
	VListBox(gb)
Level XIII
Things like this will get easier once 🙏 Expression Indexing: read and write access will be available in future version of JMP ...
Then you don't have to prepare the different parts and then construct your final expression, you can directly create a draft of the final expression and then manipulate it on any level you want.
e.g. add Y column to an existing Graph builder Expression via :
gbExpression= Expr(Graph Builder(Variables(X(:height))));
Insert Into ( gbExpression["Variables"], Expr(Y(:age)))
ARETI052
It worked! Thank you so much!
