LargeElk892
Flowchart in JSL
I'd like to draw a flowchart in JSL (cf. attachment) using a From/To table. A bit like Visio.
I've tried the Diagram option but the Cause/Effect fishbone doesn't give the same thing.
Do you know if it's possible?
Thank you
Craige_Hales
Re: Flowchart in JSL
GraphBuilder Powers for Fishbone/hierarchical Diagram Platform  seems to be accumulating these requests; it would be great if you could elaborate on your need there.
  • a platform solution?
  • scriptable with JSL?
  • what sort of input drives it?
  • run it again with new data and automatically lay out the nodes and connections?
 @MathStatChem points out there is a need for more than the simple acyclic fishbone graphs, such as the one you show with loops.  @LauraCS  might have some insight here as well; Structural Equation Modeling: The arrival of a powerful new framework in JMP Pro 15 has a diagram which I think can include loops, though it is application specific.
Craige
LauraCS
The SEM platform can build highly customizable path diagrams but it won't allow you to include content inside the nodes beyond a label (which comes from a column name in the data table). Indeed, because the diagram is application specific, the nodes aren't designed to fit a lot of content.
You can try running the JSL below to see it for yourself. As a side note, you can specify the diagram interactively using From/To lists if you just run the first two lines of the script. You'll be able to connect nodes with double-headed arrows and can use the context menu in the diagram to find the "Customize Diagram..." menu.
// Create data for use in the structural equation models platform
mat = J(50, 7, Random Normal());
As Table(mat, << Column Names({"A", "B", "C1", "C2", "C3", "C4", "D"})) << Set Name("Flow Chart");
// Launch SEM and specify diagram
obj = Structural Equation Models(Model Variables(1::7));
obj << Model Specification(
	Regressions( // lists follow "from-to" convention
		{:A,{:B}},
		{:B, {:C1, :C2, :C3, :C4}},
		{:C1, {:B}},
		{:C2, {:B}},
		{:C3, {:B}},
		{:C4, {:D}},
		{:D, {:C4, :A}}
	Path Diagram Properties(
		Manifest Shape({Width(70), Height(40)}),
		Layout("Top to Bottom")
You can get a quick overview of what the SEM platform is meant to do here:
https://www.jmp.com/en/statistics-knowledge-portal/structural-equation-modeling
HTH,
~Laura
Laura C-S
