JMPPRO
How to add Kurtosis and Skewness to Tabulate
I would like to add "Kurtosis" and "Skewness" to my row table. How do I do that?
dt = Current Data Table();
tab = dt << Tabulate(
    Show Control Panel( 0 ),
    Add Table(
        Column Table( Analysis Columns( :VAR1, :VAR2, :VAR3, ) ),
        Row Table( Statistics( Mean, Std Dev, Min, Max, Range, CV, Median ) )
Wait( 0.1 );
dtTab = tab << makeIntoDataTable;
Write( "Make a new data table from the Tabulate Platform", "\!N" );
Re: How to add Kurtosis and Skewness to Tabulate
I think you cannot get kurtosis and skewness through tabulate but they can be found from Distribution platform.
  1. Create Distribution with only distributions with the variables you are interested in
  2. Hold CTRL (this will make the options affect all of the distributions) and click red triangle in one of the distributions of the variables
  3. Go to Display Options / Customize Summary Statistics -> select statistics you are interested in
  4. Right click on one of the summary statistics tables in Distribution platform and choose Make Combined Data Table
  5. Split result data table if needed
Example script with Semiconductor Capability sample data (scripts copy pasted almost directly from JMP):
platform = dt <<
Distribution(
	Continuous Distribution(
		Column(:NPN1),
		Summary Statistics(1),
		Customize Summary Statistics(
			Std Err Mean(0),
			Upper Mean Confidence Interval(0),
			Lower Mean Confidence Interval(0),
			N(0),
			Skewness(1),
			Kurtosis(1),
			CV(1),
			Minimum(1),
			Maximum(1),
			Median(1)
		Process Capability(0)
		Column(:PNP1),
			Std Err Mean(0),
			N(0),
			Skewness(1),
			Kurtosis(1),
			CV(1),
			Minimum(1),
			Maximum(1),
			Median(1)
		Column(:PNP2),
			Std Err Mean(0),
			N(0),
			Skewness(1),
			Kurtosis(1),
			CV(1),
			Minimum(1),
			Maximum(1),
			Median(1)
	Histograms Only
Wait(0);
dt_statistics = Report(platform)[Outline Box("Distributions")][Outline Box("NPN1")][
Outline Box("Summary Statistics")][Table Box(1)] << Make Combined Data Table;
Report(platform) << Close Window;
Close(dt, no save);
dt_split = dt_statistics << Split(
	Split By(:Column 1),
	Split(:Column 2),
	Group(:Y),
	Sort by Column Property
Close(dt_statistics, no save);
platform = dt <<
Distribution(
		Column(:NPN1),
			Std Err Mean(0),
			N(0),
			Skewness(1),
			Kurtosis(1),
			CV(1),
			Minimum(1),
			Maximum(1),
			Median(1)
		Column(:PNP1),
			Std Err Mean(0),
			N(0),
			Skewness(1),
			Kurtosis(1),
			CV(1),
			Minimum(1),
			Maximum(1),
			Median(1)
		Column(:PNP2),
			Std Err Mean(0),
			N(0),
			Skewness(1),
			Kurtosis(1),
			CV(1),
			Minimum(1),
			Maximum(1),
			Median(1)
	Histograms Only
Wait(0);
Close(dt, no save);
	Split(:Column 2),
	Group(:Y),
Byron_JMP
That's really a pretty good question, maybe reframing it another way..
Rather than combining statistics, using complex scripting, wouldn't it be easier if Tabulate included more, or maybe all the univariate statistics included in the distribution platform?
..Yes, yes it would.
I'm staff, so I can't do this, but you could add this to the Wish List (its in blue menu bar at the top of the window.)
hogi
Level XIII
besides Tabulate, the same holds for:
- Tables/Summary
- and the Summary Statistics in Graph Builder!
I submitted the idea to synchronize the statistics options of the different platforms Together with Col N Categories (:green_heart:).
The original title was something like  Col N Categories - and all the others ...
Col N Categories will come with JMP 19 (with the name Col N Unique()) - so, the wish got marked as "delivered".
 "for all the others" - here is a new wish:synchronize Summary Statistics (Tables/Summary - Tabulate - Graph Builder Summary Statistics - Distr...
unfortunately, it starts again with 0 Kudos : (
Still a long time till it gets the chance to get into a future version of JMP - but maybe somebody sees this post and says:
I'm staff, [and] I can[] do this.
