jacksonperry
Flagging an error if variable name does not match
Hi all,
I want to build a simple error trap where it will flag the error if the variable name from the user defined variable name with the existing table variable name. For example as below;
User defined Data table
Variable Name
1. Benzene
2. Methane
3. Ethane
Existing Data Table
Variable Name
1. Benzene
2. Methane
3. Ethane
4. Propane
5. Pentane
6. Hexane
I tried to used !contains function, but it seemed that I dont use the syntax properly. I'm a very new to jmp script, so I'm seeking for anyone in the community help
Inputdt = User Defined Data Table Name
mvdt = Existing Data Table Name
//Get required variable lists from user define Data Table
varListInput = Column( Inputdt, "Variable Name" ) << get values;
// Error trap - if # UserDefinedTable & # Existing Data Table variables don't match, then break code & output error message.
//Obtain column names from existing Data Table from list
colnames = mvdt << get column names( string );
show(colnames);
show(varListInput);
If(!contains Item ("colnames", "varListInput"),
	Message = Dialog( "The Variable Name does not match with Existing Data Table.Please correct your Input Table." );
	Stop();
Re: Flagging an error if variable name does not match
The Contains Items() function requires the data to be in Associative Arrays.  If your items are in lists, the below method will work.
mvdt = Existing Data Table Name;
show(colnames);
show(varListInput);
For( i = 1, i <= N Items( varListInput ), i++,
	If( !Contains( colnames, varListInput[i] ),
		Message = Dialog(
		Stop();
show(colnames);
show(varListInput);
		Message = Dialog(
		Stop();
jacksonperry
Thank you, it is working fine now
