jlmbs
Fix error: Send Expects Scriptable Object in access or evaluation of 'List
I am trying to write a JSL to get the summary of replicates on a concatenated data table. The code below throws an error, could you tell why and how to fix it?
dt_summary=dt_concatenated_lst << Summary(
	Group( :Sample name ),
	Mean( :"A280 Concentration(mg/ml)"n ),
	Mean( :"AvgA280 Concentration (mg/ml)"n ),
	Mean( :"CVA280 Concentration (%)"n ),
	Freq( "None" ),
	Weight( "None" ),
	Link to original data table( 0 )
Re: Fix error: Send Expects Scriptable Object in access or evaluation of 'List
What is the value of your variable named
dt_concatenated_lst
It needs to be of the form
Data Table( "xxxxxxx" )
where "xxxxxxx" is the name of the data table you want to be summarized.  Given the name of the variable, I am guessing the variable is a JMP list, not a simple data table reference.
dt_concatenated_lst
