dainius
Fitting Poisson distribution
Dear all,
I am using JMP 15. When I aim to fit the Poisson or Negative binomial as the distribution and plot it on top of count data, I get the error:
'Exception in platform popup command'.
I have the Fitted Poisson Distribution parameters appearing, but here I can only add Normal curve, not the Poisson.
Does anybody know why?
Thank you.
Re: Fitting Poisson distribution
This is a problem that was corrected in 15.2.  You need to upgrade to the latest version.
dainius
Do you know what issue could it be that I cannot update? My version is 15.1 now.
Thanks,
Dainius
Do you have JMP Pro, and downloaded the JMP upgrade and not the JMP Pro upgrade?
dainius
No, we do not have a Pro version, only 15.1.0.
I suggest you contact JMP Support
support@jmp.com
dainius
Thank you :)! I have done so now.
