lukasz
How to display the last tab in the window by using the Tab Box?
Hello Everybody,
I have the following issue: I am creating a series of tabs within the Param_Overview window. Those tabs are generated in "for" loop. After the last tab, however, I would like to create one more tab created outside the for loop. The generation of tabs from the "for" loop works well but the addition of the last one does not. If I select by hand the code of the last tab and execute it, then the desired tab shows up in the windows as well. For creating the tabs in "for" loop the data table dt_run is used. For creating the last tab another table is used: zuv_data. How to activate the generation of the last tab? I would appreciate for hints and suggestions how to do that. I removed the content how each graph is created in order to simplify the code structure.
Best regards.
New Window( "Param_Overview", tb = Tab Box() );
For( iRun = 1, nitems(run_list), iRun++,
	tb << Add(
		//todo
		Lineup Box( N Col( 1 ),
			Outline Box( "Graph1",
				H List Box(
					dt_run << Graph Builder(
						// todo
						// todo
			Outline Box( "Graph2",
				hlistbox = H List Box(
						// todo
					dt_run << Tabulate(
						// todo
// the last tab
tb << Add("last tab",   //add one more tab
	Outline Box( "Last_Graph",
	H List Box(
	zuv_data << Graph Builder(
		// todo
Re: How to display the last tab in the window by using the Tab Box?
I filled out your example script, and corrected a couple syntax issues, and the code runs without error.
Errors
  1. Your For() loop is an infinite loop.  Your code's ending element is never reached.
    It needs to be
    For( iRun = 1, iRun <= nitems(run_list), iRun++,
  2. There was an issue with having matching ")" in the For Loop
Here is my rework of the code
dt_run = open("$SAMPLE_DATA/big class.jmp");
zuv_data = open("$SAMPLE_DATAbig class families.jmp");
run_list = {a, b};
For( iRun = 1, iRun <= N Items( run_list ), iRun++,
	tb << Add(
		//todo
				H List Box(
						Size( 528, 450 ),
						Show Control Panel( 0 ),
						Variables( X( :age ), Y( :height ) ),
						Elements( Points( X, Y, Legend( 3 ) ) )
					Size( 528, 450 ),
					Size( 528, 450 ),
			dt_run << Tabulate(
				Add Table(
					Column Table( Analysis Columns( :height, :weight ), Statistics( Mean ) ),
					Row Table( Grouping Columns( :age ) )
// the last tab
tb << Add(
		H List Box(
			zuv_data << Tabulate(
				Add Table(
lukasz
Thank you!, it is working. I completely did not notice the error in For() loop. That is why it was not able to display the last tab. Best regards
