UserID16644
Fit Y by X Spline fit color
I have a fit Y by X plot with smoothing spline fit, is there any way that I can make the marker colors gray and the spline fit line in JMP default color? I tried changing the color theme into medium light gray, but it's not working
rbiv[Framebox( 1 )] << Row Legend( Column( col1 ), Color( 1 ), Marker( 0 ), Color Theme("JMP Default"), Continuous Scale( 0 ) );
10 REPLIES 10
ThuongLe
Re: Fit Y by X Spline fit color
You can right click on the graph and select "Customize"
then select the color you want
Then export the script to window to see the real code behind
Oneway(
	Y( :Yield ),
	X( :WW ),
		Dispatch(
			"Oneway Plot",
			FrameBox,
			{DispatchSeg(
				Marker Seg( 1 ),
				{Color( "Orange" ), Marker( "Triangle" )}
Thuong Le
UserID16644
Hi, I tried this method but it is not working when I put it into my function
ThuongLe
Can you share your full code?
Thuong Le
UserID16644
Here's the function:
bivht = Function( {x_param, y_param, htt},
    biv = Bivariate(
        Y( Column( y_param ) ),
        X( Column( x_param ) ),
        GroupBy( Column( ht ) ),
        <<Fit Spline( 1000, {Line Width( 2 )} )
    rbiv = biv << Report;
    rbiv[Framebox( 1 )] << {Marker Size( 3 )};
    rbiv[Axisbox( 2 )] << Tick Font( style( 0 ), size( 9 ) ) << Show Major Grid( 1 ) << Show Minor Grid( 1 ) <<
    Show Minor Ticks( 1 );
    rbiv[Axisbox( 1 )] << Tick Font( style( 0 ), size( 9 ) ) << Show Major Grid( 1 ) << Show Minor Grid( 1 ) <<
    rbiv[Text Edit Box( 2 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
    rbiv[Text Edit Box( 1 )] << Set Font Size( 10 ) << Set Font Style( "Bold" );
    rbiv[Outline Box( 1 )] << Set Title( y_param || " by " || x_param );
    rbiv["Smoothing Spline Fit, lambda=1000 ?"] << Close All Like This;
        Column( ht ),
        Color( 1 ),
        Marker( 0 ),
        Color Theme( "JMP Default" ),
    rbiv[Border Box( 2 )] << Delete;
    pbiv = rbiv[Outline Box( 1 )] << get picture;
ThuongLe
Is this a typo or you have another variable named "ht"
Thuong Le
UserID16644
ht is a variable name
ThuongLe
I mean in your function, you define htt but you never use it. Instead, you use ht
That could be the issue
Thuong Le
UserID16644
lb = Lineup Box( N Col( 4 ) );
For( j = 1, j <= N Items( xparam ), j++,
    bivht( xparam[j], yparam[j], h );
    lb << append( pbiv );
    biv << Close Window;
ppt9 << append( lb << get picture );
ThuongLe
I'm lost now :D
Thuong Le
