johnm
Community Trekker
Fit Y by X Graphs created in a row rather than column?
The Fit Y by X when used to plot multiple Y,Responses and/or to plot multiple By variables, creates the plots in a single column.
I am wondering if there is way to make the plots appear in a row instead.
I have limited success trying to script such. But please if there are some methods to make this possible, please post.
thanks,
John
Re: Fit Y by X Graphs created in a row rather than column?
I am glad that the scripting option works for you, but regular JMP version 12 does still have the ability to arrange the graphs in rows. Perhaps this screen capture will show you where to click. The VERY TOP outline item will say Fit Group. That red pop-up will have the Arrange in Rows.
Although this screen capture was on Oneway and not Bivariate, it looks exactly the same for Bivariate.
Dan Obermiller
12 REPLIES 12
look under the red triangle, and select "Arange in Rows".
johnm
Community Trekker
Hi Jim,
in the Graph > Cell Plots menu I do find:  it seems X,Grouping warns when using continuous data, and prefers nominal or ordinal. (I am plotting continuous data.)
In Fit Y by X, in the plots I am making, there are four graphs produced and these graphs are in a single column aka one column and four rows in my output window. I have an interest to have the four graphs in a single row aka, one row and four columns.
Thanks,
John
After you have run your plots in Fit Y by X, you can go to the red triangle in the output, and select Rarange in Rows
Which will give you
What am I missing?
johnm
Community Trekker
Looks like what you're missing is you are using JMP Pro.
I am using JMP12. That is probably this issue.
At least that is what I suspect as to why I do not see that menu.
I suspect you are correct.  Yes, I am running JMP Pro.  If running a script fits into your posibilities of a solution, here is a very simple script that will do what you want
dt = Open( "$SAMPLE_DATA/semiconductor capability.jmp" );
ycolList = {"NPN1", "PNP1", "NPN2", "PNP2"};
New Window( "FIT By Y Outputs",
	H List Box(
		For( I = 1, i <= N Items( Ycollist ), i++,
			Oneway( Y( Column( dt,ycollist[i] ) ), X( :wafer ) )
johnm
Community Trekker
Hi Jim,
Your script was helpful. Thanks.
Example using the H List Box() in the following script does the trick:
dt = Open( "C:\Program Files\SAS\JMP\12\Samples\Data\Semiconductor Capability.jmp" );
dt:SITE << modeling type(continuous);
dt << select where (:lot_id == "lot1" | :lot_id == "lot2");
dt << invert row selection;
dt << hide;
dt << exclude;
dt << select where (:wafer == 1 | :wafer == 2);
dt << hide;
dt << exclude;
dt << clear select;
new window("example",
H List Box(
Bivariate( Y( :NPN1 ), X( :SITE ), by (:lot_id, :wafer) );
vladbondarenko0
Community Trekker
Hi John,
You should see this function in JMP12 ("Arrange in Rows"). Click red triangle under "Fit Group".
Vlad
johnm
Community Trekker
Hi Vlad,
Could not find "Arrange in Rows" in the Bivariate Fit in JMP12. Maybe an example can show the detail.
However, the following script makes use the of horizontal list box:
dt << hide;
dt << exclude;
dt << hide;
dt << exclude;
dt << clear select;
H List Box(
Just as H List Box() created the horizontal layout that you prefer, Line Up Box( n cols, ... ) gives similar layout but allows you to have wrap the contents with n cols items per row.if it is getting too wide for you.
