LGaspard_98
Fit Spline for multiple columns and saving predicted values
Hi all,
I have a lot of different columns from an FTIR spectra experiment, and in order to correct the baseline, I need to perform a Fit Spline on each column (one column = one spectra). I would like to do this automatically using JSL, so I don't have to save hundreds of "Predicted values" by hand.
I tried to create a code but somehow it doesn't want to save the values or put 0 in each columns.
Could anyone help for that?
Below is my code:
// Define the columns for the fit (assuming multiple Y columns and one X column)
x_col = Column("Wavenumber"); // Replace with the name of your X column
y_cols = {};
For(i = 1, i <= N Col(dt), i++,
	col_name = Column(i) << Get Name;
    // Check if the column name contains "Absorbance at t="
	If(Contains(col_name, "Absorbance at t="),
		Insert Into(y_cols, col_name);  // Add to the list
// Create a list to store fit reports
fit_reports = {};
// Perform Fit Y by X for each Y column separately and display the fit
For(i = 1, i <= N Items(y_cols), i++,
	y_col = y_cols[i];
	fit_report = dt << Fit Y by X(
		Y(Column(y_col)),
		X(x_col),
		Fit Spline(1000) // Adjust the lambda (smoothing parameter) as needed
	Insert Into(fit_reports, fit_report);
Show(
	"All fits have been displayed. Please review them and adjust the lambda value in the script if needed."
// Wait for user to review fits
Wait(0);
// Use a Yes/No dialog to prompt the user to continue or stop
result = New Window("Save Predicted Values?",
	Text Box("Are you satisfied with the fits? Click Yes to save predicted values, No to stop."),
	Button Box("Yes",
        // Save predicted values as columns in the dataset
			y_col = y_cols[i];
			fit_report = fit_reports[i];
			predicted_col_name = "Spline Predictor for " || y_col;
			dt << New Column(predicted_col_name, Numeric);
			Column(predicted_col_name) << Set Values(fit_report["Prediction Formula"]);
		Show("Predicted values saved successfully.");
	Button Box("No",
		Show("Predicted values were not saved.");
// Close all fit reports
For(i = 1, i <= N Items(fit_reports), i++,
	Close(fit_reports[i], No Save);
Close(result); // Close the dialog window
Edit 2024-09-24 jthi: added jsl formatting
Re: Fit Spline for multiple columns and saving predicted values
This might give some ideas
dt = Open("$SAMPLE_DATA/Semiconductor Capability.jmp");
xcol = "NPN1";
ycols = {"PNP1", "NPN2"};
fits = {};
For Each({ycol}, ycols,
	Insert Into(fits,
		dt << Fit Y by X(
			Y(Eval(ycol)),
			X(Eval(xcol)),
			Fit Spline(1000)
close_expr = Expr(
	For Each({fit}, fits,
		fit << close window;
	nw << Close Window;
nw = New Window("Save Predicted Values?",
	Button Box("Yes",
			fit << (Curve["Smoothing Spline Fit, lambda=1000"] << Save Predicteds);
		wait(0);
		close_expr;
	Button Box("No",
		close_expr;
I would also collect all the Fit Y by X to single window so it is easier to check them instead of opening multiple separate windows
xcol = "NPN1";
fits = {};
	Insert Into(fits,
		dt << Fit Y by X(
			Y(Eval(ycol)),
			X(Eval(xcol)),
			Fit Spline(1000)
close_expr = Expr(
	nw << Close Window;
	Button Box("Yes",
		wait(0);
		close_expr;
	Button Box("No",
		close_expr;
LGaspard_98
It worked amazingly, thank you so much! I've been struggling with ChatGPT to find a solution for hours :D
