skyzvoir0001
Fit Group Automate
Im working with this code but somehow on the 9th output, it gets an error. Parameters_1 contains 23 items on it.
current data table(subs);
for (i = 1, i <= nitems(parameters_1), i++,
    print(i);
  Oneway(
        X( :Recipe ),
        Y( column(subs, parameters_1[i]) ),
                With Control(1),
                Quantiles(1),
                Means and Std Dev(1),
                CDF Plot(1),
                Mean Error Bars(1),
                Std Dev Lines(1),
        SendToReport( Dispatch(  {}, "Fit Group", OutlineBox, {Set Title( "TYPE="||char(type)||"" )} ) )
The outputs from 1-8 are shown individually. How do I code such that my output is arranged by 2 and save it into a ppt.
Re: Fit Group Automate
Concerning your error on parameter 9....what is the error that is displayed in the log?
Below is a modification to your code that will display all of the outputs in 2 columns.  It also has the code to save the output to PowerPoint.
Current Data Table( subs );
nw = New Window( "Oneways",
	Lineup Box( N Col( 2 ),
		For( i = 1, i <= N Items( parameters_1 ), i++,
			Print( i );
			Oneway(
				X( :Recipe ),
				Y( Column( subs, parameters_1[i] ) ),
				With Control( 1 ),
				Quantiles( 1 ),
				Means and Std Dev( 1 ),
				CDF Plot( 1 ),
				Mean Error Bars( 1 ),
				Std Dev Lines( 1 ),
					Dispatch(
						"Fit Group",
						OutlineBox,
						{Set Title( "TYPE=" || Char( type ) || "" )}
nw << save presentation("$TEMP\reportppnw.pptx");
However, this will not display 2 graphs per page.  By convention, JMP will place each graph on a separate slide.  To handle this, I typically create a journal where pairs of outputs have been copied over as pictures, and then at the end, the journal is saved to a pptx.  For that, something like below might work.
For( i = 1, i <= N Items( parameters_1 ), i = i + 2,
	hlb = H List Box(
		Oneway(
			X( :Recipe ),
			With Control( 1 ),
			Quantiles( 1 ),
			CDF Plot( 1 ),
			Std Dev Lines( 1 ),
				Dispatch(
					"Fit Group",
					OutlineBox,
		Try(
			Oneway(
				X( :Recipe ),
				Y( Column( subs, parameters_1[i + 1] ) ),
				With Control( 1 ),
				Quantiles( 1 ),
				CDF Plot( 1 ),
				Std Dev Lines( 1 ),
					Dispatch(
						"Fit Group",
						OutlineBox,
		zippy = hlb << get picture;
		zippy << save presentation( "$TEMP\report.pptx", append );
BTW.....I did not completely test the code.  Therefore, there might be a slight issue or two, but the concepts are correct.
skyzvoir0001
update: fixed the output part- it now outputs from 1-23, my problem is how do i append it to ppt arranged in 2 or 3 plots per slide?
			Print( i );
			Oneway(
				X( :Recipe ),
				With Control( 1 ),
				Quantiles( 1 ),
				CDF Plot( 1 ),
				Std Dev Lines( 1 ),
					Dispatch(
						"Fit Group",
						OutlineBox,
	hlb = H List Box(
		Oneway(
			X( :Recipe ),
			With Control( 1 ),
			Quantiles( 1 ),
			CDF Plot( 1 ),
			Std Dev Lines( 1 ),
				Dispatch(
					"Fit Group",
					OutlineBox,
		Try(
			Oneway(
				X( :Recipe ),
				With Control( 1 ),
				Quantiles( 1 ),
				CDF Plot( 1 ),
				Std Dev Lines( 1 ),
					Dispatch(
						"Fit Group",
						OutlineBox,
skyzvoir0001
thanks for this!
skyzvoir0001
Fit Group(
		hlb = H List Box(
			Oneway(
				X( :Recipe ),
				Y( Try( Column( subs, parameters_1[i] ) ) ),
				With Control( 1 ),
				Quantiles( 1 ),
				CDF Plot( 1 ),
				Std Dev Lines( 1 )
			Try(
				Oneway(
					X( :Recipe ),
					With Control( 1 ),
					Quantiles( 1 ),
					CDF Plot( 1 ),
					Std Dev Lines( 1 )
I tried the code you gave but somehow this gives me an error:
Not Found in access or evaluation of 'Oneway' , Bad Argument(
{Try( Column( subs_top, parameters_1[i] ) ), Role requires at least 1 columns.}
), Oneway(/*###*/X( :Recipe ),
Y( Try( Column( subs_top, parameters_1[i] ) ) ),
With Control( 1 ),
Quantiles( 1 ),
CDF Plot( 1 ),
Std Dev Lines( 1 )
Fit Group[]
skyzvoir0001
but when trying the code i came up earlier,
t0p = Fit Group(
		Oneway(
			X( Column( subs, "Recipe" ) ),
			With Control( 1 ),
			Quantiles( 1 ),
			CDF Plot( 1 ),
			Std Dev Lines( 1 )
	SendToReport( Dispatch( {}, "Fit Group", OutlineBox, {Set Title( "TYPE=" || Char( type ) || "" )} ) )
) << {Arrange in Rows( 2 )};
works but it does it individually.
