SMast
Splitting columns
i have a column full of dates with different time points in the date. Eg:
2020-01-31T11
2020-01-31T12
2020-01-31T13
2020-01-31T14
2020-01-31T15
2020-01-31T16
2020-01-31T17
2020-01-31T18
2020-01-31T19
2020-01-31T20
2020-01-31T21
2020-01-31T22
2020-01-31T23
2020-02-01T00
2020-02-01T01
but I want to split them into two separate columns: date and time. I'm a beginner so I'm still getting use to the software.
thanks!
dale_lehman
Re: Splitting columns
You can use the Left, Substring, and or Right functions (found in the Character group in the formula window) to create 2 new columns, one with the date and the other with the hour (I am assuming the last two digits are the hour and the T just stands for time).  Then, make sure the date column yyyy-mo-day is formatted as a date.  So, to get the date you could use Left(current column, 10) and for the hour you could use Right(current column, 2).
I have attached you sample data table and have added 2 columns.  The formula I used for the first column is:
Informat( Substr( :Column 1, 1, 10 ), "Y/m/d" )
It was a pretty straight forward conversion, because the substringed data matched an existing Informat().
The second column formula is:
Informat( Substr( :Column 1, 12, 2 ) || ":0", "hr:m" )
The format required needs to have minutes along with the hour, so I just had to add it to the string returned from the Substr() function
I hope this helps you with your journey into using JMP
