Srishti
Fischer's exact test odds ratio and Confidence intervals
I am a regular user of JMP, but without experience in scripting. I have used Fischer's exact test on my analysis, and am getting the results as posted. I have 2 questions:
1. Why do I get 2 difference exact tests and p-values? Which is the one to use?
2. In the odds ratio, the confidence interval does not match the p-value (which is <0.05). I am guessing it has something to do with the way with the CIs are calculated. Can you advise the best way to calculate the exact CI here? I am not experiencing this issue with other exact analyses used in the same dataset
Thanks
12 REPLIES 12
Re: Fischer's exact test odds ratio and Confidence intervals
I do not have access to JMP computer codes. I recommend that you send your question about the effect of weighting the contingency table analysis to JMP Technical Support ([email protected]). Please report back here what you learn from them so that other Community members may learn from your experience.
Srishti
I reached out to JMP support. The issue was that the weights used were non-integer weights. On using rounded integer weights, the discrepancy in the Odds ratio CIs and p-values disappeared.
Unfortunately, it seems JMP cannot handle non-integer weights. It would be useful to have this feature !
Yeah.
