All,
I got stuck on a seemingly easy step.
My table is compiled from multiple CSV files. Where those files were previously concatenated, there is one service row that is empty except first three columns where it says something like "### Switching Logging: datetime" in the first column and then from which file in second coumn and to what file in third column. So, a trash row that I want to delete. The only common thing about those rows is word "Switching" in the first column. Plus the name of the first column has semicolon, something like index:date and I need to keep it that way. How do I find and delete those rows without creating new columns?
I tried something like this:
db_test << Get Rows Where (Contains("Switch", Column(1)));
But it doesn't work, apparently Contains() only takes columns that are refered to as :columnname. But since I have ":" in the name of my column so I cante refer to it as ":index:date". Even if I rename the column, it apparently doesn't work.
How to do this in one line?
