CMG
CMG
Find and identify duplicates for unsorted data
Fairly new to JMP, so my knowledge of how to use formulas is pretty limited.
If I have a column of values (character) and I want to identify them as duplicates in a different column, what formula would I use? (My data has 10 columns already sorted by a different column's values)
In the past, I have used the formula below (when the data that needs duplicates identified has been sorted alphabetically).
If(
	Row() == 1, 1,
	:Column1 != Lag( :Column1 ), 1,
	0
Since I am not allowed to present data sorted in any other way than the way it comes in, I am kind of at a loss as to how to indicate duplicates.
Any and all help is appreciated.
Re: Find and identify duplicates for unsorted data
Below are at least two ways to do this with scripting:
dt = New Table("Untitled",
	Add Rows(7),
	Compress File When Saved(1),
	New Column("Column 1",
		Numeric,
		"Continuous",
		Format("Best", 12),
		Set Values([1, 1, 2, 3, 2, 5, 1]),
		Set Display Width(60)
dt << New column("Dublicate_formula", Numeric, <<Formula(
	If(Col Rank(1, :column 1) > 1, 1,0))
dt << Select duplicate rows(Match(:column 1));
dubRows = dt << Get Selected Rows;
dt << New Column("Dublicates", Numeric, Nominal);
Column(dt, "Dublicates")[dubRows] = 1;
Column(dt, "Dublicates")[dt << Get Rows Where(IsMissing(:Dublicates))] = 0;
You can also do this without any scripting:
  1. Select columns you are interested in.
  2. From Rows menu: Row Selection -> Select Dublicate Rows
  3. Rows menu: Row Selection -> Name Selection In Column
  4. Choose name, Selected as 1 and Unselected as 0
Mauro_Gerber
Maybe this line helps
dt << Select duplicate rows( Match( :column_1, :column_2, :column_3) );
This will select rows that are not unique in the upper combination of column 1 to 3.
With the selection you can now delete, hide and exclude, fill an additional column or what you want to do with them.
r_select = dt << select rows( dt << get selected rows ); // this gets you a vector of row number.
r_select << Delete Rows;
// or
r_select << Hide and Exclude;
"I thought about our dilemma, and I came up with a solution that I honestly think works out best for one of both of us"
- GLaDOS
CMG
CMG
Thank you for the response.
I don't think I explained myself well. What I want is a helper column to indicate if a certain value is duplicate, maybe with a "1" indicating all duplicates, and a "0" indicating no duplicates. I do not want to hide or delete the duplicates.
	Add Rows(7),
		Numeric,
		"Continuous",
		Format("Best", 12),
CMG
CMG
Thank you very much. I was able to mark without using the scripting.
Appreciate your help!
You can also do this as a formula column using the below formula which is using the Big Class data table as an example
If( Row() == 1,
	Current Data Table() << select duplicate rows(
		Match( :age, :sex, Empty() )
If( Selected( Row State( Row() ) ),
	"Group 1",
	"Group 2"
ms
Super User (Alumni) ms
Here's another example using a column formula.
// Create a column that indicates duplicate names (there are two "Robert")
dt << New Column( "Duplicate", Formula( If( Col Number( Row(), :name ) > 1, 1, 0 ) ) );
