robot
Find All Display Tree Elements
I would like to use JSL to get a list of all the objects within a display tree for scripting purposes.  Specifically, I would like to get a list of all the FrameBoxes within a window, and then add a graphics script to each.  Or better still, I would like to return a list of available FrameBoxes to the user, and then have the user select which graphics script to add.
How can I get a list of all the FrameBoxes in a window?  I would like to get a list that is in a form suitable for scripting, and not just view the Display Tree.  Is this possible?
ian_jmp
Level X
Re: Find All Display Tree Elements
That's perfectly possible. The code below uses pre-order traversal to walk the display tree (and was originally written by Joseph Morgan in the JMP Division, I believe). You should be able to get what you need with a few tweaks (depending on the rest of your code).
NamesDefaultToHere(1);
ClearLog();
// This function recursively traverses a display tree producing
// a pre-order listing of the names of display boxes that constitute
// the tree. It also looks for each FrameBox (whether displayed or not),
// and gets the name of the parent OutlineBox
preorder = Function({node},
   Local({chnode},
  // Inspect the current node
  nodeType = Char(node << className);
      Print("Node: "||nodeType);
      If(nodeType =="FrameBox",
// Find the title of the parent outline node of this FrameBox
parent = node << parent;
parentType = Char(parent << className);
While(parentType != "OutlineBox",
parent = parent << parent;
InsertInto(fbTitles, parent << getTitle)
  // Do the recusrsion
      chnode = node << child;
      While(IsScriptable(chnode),
         Recurse(chnode);
         chnode = chnode << sib;
// Try out 'preorder' . . .
obj = dt << Fit Model(
Y( :height ),
Effects( :sex ),
Emphasis( "Effect Leverage" ),
Run(
:height << {Lack of Fit( 0 ), Plot Actual by Predicted( 1 ),
Plot Regression( 0 ), Plot Residual by Predicted( 1 ),
Plot Effect Leverage( 1 )}
report=report(obj);
fbTitles = {};
preorder(report);
Print("\!n", fbTitles);
14 REPLIES 14
ian_jmp
Level X
ClearLog();
   Local({chnode},
         Recurse(chnode);
Y( :height ),
Effects( :sex ),
Run(
report=report(obj);
fbTitles = {};
preorder(report);
robot
Thanks Ian.
robot
Hi Ian@JMP,
Thanks again for the preorder function.  Is there a way for the function to return only FrameBoxes that are actually displayed?  Or is there a way for JMP to tell which FrameBoxes are displayed or not?
I find that when my script tries to send a command to a FrameBox that is not displayed, it will cause an error.
ian_jmp
Level X
Not really answering your question directly, but you may be able to make the failure you mention benign by using the 'Try()' function.
robot
Okay.  Thanks Ian.  An unfortunate side-effect of the returned hidden FrameBoxes is that the FrameBox title may not match up with the FrameBox number as shown below.  I may be able to get my script to work using some other variations on the Try() function.
Clear Log();
preorder = Function( {node},
       Local( {chnode},
             nodeType = Char( node << className );
             Print( "Node: " || nodeType );
             If( nodeType == "FrameBox",
                    parentType = Char( parent << className );
                    While( parentType != "OutlineBox",
                    Insert Into( fbTitles, parent << getTitle );
             While( Is Scriptable( chnode ),
                    Recurse( chnode );
       Y( :height ),
       Effects( :sex ),
       Run(
             :height << {Lack of Fit( 0 ), Plot Actual by Predicted( 1 ), Plot Regression( 0 ), Plot Residual by Predicted( 1 ), Plot Effect Leverage( 1 )
report = Report( obj );
fbTitles = {};
preorder( report );
Print( "\!n", fbTitles );
// Select windows.
Wait( 1 );
obj << Bring Window to Front;
For( i = 1, i <= N Items( fbTitles ), i++,
       Try(
             report[FrameBox( i )] << Select;
             win = New Window( "FrameBox Title", <<Modal, Text Box( Eval( fbTitles[i] ) ) );
             report[FrameBox( i )] << Deselect;
ms
Super User (Alumni) ms
Interesting discussion. Below is an example, borrowing heavily from the examples above, where I use an associative array to link the present numbers of displayed frame boxes with their titles.
    Y(:height),
    Effects(:sex),
    Personality("Standard Least Squares"),
    Emphasis("Effect Leverage"),
    Run(
        :height << {Lack of Fit(0), Plot Actual by Predicted(1), Box Cox Y Transformation(1), Plot Residual by Predicted(1),
        Plot Effect Leverage(1)}
report = Report(obj);
// Associative array linking displayed framebox numbers with titles
fbTitles = [=> ];
i = 1;
While(Is Scriptable(Try(parent = Report[Framebox(i)] << parent)),
    While(parentType = Char(parent << className) != "OutlineBox", parent = parent << parent);
    fbTitles << insert item(i, parent << getTitle);
    i++;
Show(fbTitles);
// Select windows.
For(i = 1, i <= N Items(fbTitles), i++,
    report[FrameBox(i)] << Select;
    win = New Window("FrameBox Title", <<Modal, Text Box(Eval(fbTitles[i])));
    report[FrameBox(i)] << Deselect;
robot
Thanks MS.
If you post your reply at the separate discussion for this follow-up question, Find Hidden or Displayed FrameBoxes, I will mark it correct.
Very impressive.
robot
Hi MS​,
Thanks again for your script; it works beautifully for JMP12.  I am now trying to make the script compatible down to JMP10, and I have having trouble debugging the script for GraphBuilder.  Do you know how to make your script work for GraphBuilder in JMP10?
// Script will work for graph1.
graph1 = dt << Fit Model(
      Y( :height ),
      Effects( :sex ),
      Run(
            Box Cox Y Transformation( 1 ), Plot Residual by Predicted( 1 ),
// Script will crash for graph2.
graph2 = dt << Graph Builder(
      Variables( X( :height ), Y( :weight ), Wrap( :age ) ),
      Elements( Points( X, Y, Legend( 1 ) ) )
Wait( 1 );
win = Current Window();
// Associative array linking displayed FrameBox numbers with titles
fbTitles = [=> ];
i = 1;
While( Is Scriptable( Try( parent = win[Framebox( i )] << parent ) ),
      While( parentType = Char( parent << className ) != "OutlineBox",
      fbTitles << insert item( i, parent << getTitle );
      i++;
Show( fbTitles );
// Select windows.
win << Bring Window to Front;
      win[FrameBox( i )] << Select;
      win[FrameBox( i )] << Deselect;
ms
I may not be able to help since I don't have a JMP 10 license. What goes wrong? Any messages in the log?
Graph Builder has evolved a lot for every new version of JMP. I think that Graph Builder's scripting support has improved too. Maybe there's a special display-box type in the v.10 Graph Builder report that is not (yet) "scriptable", causing the while-loop to stop before the search is completed.
You could also try to use Insert() instead of Insert Item().
