Filtering row values that are not within a given range (JSL)
May 20, 2019 05:45 AM(4294 views)
I am trying to automate some data cleaning. I have lower and high limit values that are considered valid per column and I want to remove verything else having at the end empty values instead. I am missing:
How to clear row values once there is a selection.
How to reference a column name
If there is a better way to do it.
lower_limit = 69.636;
higher_limit = 71.482;
sel = dt << Select Where( :my_column_name>= lower_limit &
:my_column_name<= higher_limit );
sel << Invert Row Selection;
// clear rows (sel)??
// Here I am trying to do the same but referencing the column. Yet it does not work.
mycol = Column("my_column_name"); // this does not work
mycol = :my_column_name; // this does not work either
sel = dt << Select Where( mycol >= lower_limit &
mycol <= higher_limit );
You should look up the Function As Column(). If you want to use column values, the syntax is ref_name[], that is, left bracket, right bracket. Try the syntax below.
