ileshem
Filling empty cells in a specific “character” column
I need help with filling empty cells in a specific “character” column.
I was able to find a script that does it to all numeric cells of the entire table, but I need it to edit a specific text column.
I have something like the table below and I want to fill the empty cells in the "United" column with an expression like "PASS".
so from this table:
RevOBUnited
ABC1231CB1
ABC321 CB5
CBA2134
ABC546 CB1
ABC6545
CBA2136CB1
ABC453 CB5
ABC3218
CBA2138
I will get:
RevOBUnited
ABC1231CB1
ABC321 CB5
CBA2134PASS
ABC546 CB1
ABC6545PASS
CBA2136CB1
ABC453 CB5
ABC3218PASS
CBA2138PASS
Appreciate your help.
Re: Filling empty cells in a specific “character” column
names default to here(1);
dt=current data table();
for each row(
    If(:United=="", :United="PASS");
or to do it interactively,
Type into one blank cell for column United, "PASS"
Then click on that cell and copy it to the paste buffer (Cntl/C)
Then right click on a one of the other blank cells for the column United.
Select the option, "Select Matching Cells"
All blank cells for column United will be selected
Hover over one of the selected cells, and paste into the cell the value from the paste buffer.
All selected cells will now have the word "PASS" pasted into them
Jeff_Perkinson
The fastest way to do this is to type the word "PASS" into one of the cells. Then select it and use Edit->Copy to copy it to your clipboard.
Then right-click on one of the empty cells and choose Select All Matching Cells and then choose Edit->Paste to paste PASS into all the cells.
If you want to do this programmatically let us know and I'm sure we can point you in that direction.
-Jeff
8 REPLIES 8
for each row(
ileshem
Thank you all!
What a quick respond!
I want to use a JSL to do it.
When I use that part of the script, it is not working for me:
For Each Row( If( United/*###*/ == "", United = "PASS" ) );
Name Unresolved: United{1} in access or evaluation of 'United' , United/*###*/
I should have specified a ":" in front of the reference to the column United......... :United
An even more definative reference is dt:United
Make those changes and it should work
Jeff_Perkinson
-Jeff
Jeff_Perkinson
@txnelson always beats me!
-Jeff
Here's a variation on the original request: what if you want to add different values into the empty cells. For example you have the table below, and you want to put C in the third cell, A in the fifth cell, and D in the 8th cell. is there a way to that programmatically? I had initially thought that an easy way to do it would be to add rows and fill them in with all the known letters to ensure we had all of them represented.
33A
12B
15
1D
7
22B
9C
28
There are several ways to do this.  Here is one way:
dt = New Table( "example",
	Add Rows( 8 ),
	New Column( "Value",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Set Values( [33, 12, 15, 1, 7, 22, 9, 28] )
	New Column( "Letter",
		Character( 16 ),
		"Nominal",
		Set Values( {"A", "B", "", "D", "", "B", "C", ""} )
Alphabet = "ABCDEFGHIJKLMNOPQRSTUVWXYZ";
For( i = 1, i <= N Rows( dt ), i++,
	If( :letter[i] == "",
		:letter[i] = Substr( Alphabet, i, 1 )
The code works great! Thanks for the help
