Files In Directory
With JMP 17, the Files in Directory script command appears not to work if there are leading numbers, or numbers in the file name.  The Watch window returns various errors unless all file names are number free.
<jsl> folderPath = "C:\Users\first.last\documents";
<jsl> fd = Files In Directory( folderPath,1,1 );
<jsl> w = Watch ( fd );
Is this fixed in a different release?  Suggestions?
3 ACCEPTED SOLUTIONS
Re: Files In Directory
It looks to be an issue with the way the Watch window displays the variables.  The variable "fs" is properly defined.  No issues appeared until I added the "05 Messages.xls" file.  I would just avoid the Watch() function.  Show() works in any situation, as far as I can tell.
Names Default to Here( 1 );
dir = "$DOCUMENTS\JMP Scripts\zero test\";
fs = Files in Directory( dir, 1, 1 );
w = Watch( fs );
Show( fs );
//fs = {"0 is smaller than 1", "00five-oh.txt", "0meansinfinity.txt", "Hello World.txt"};
w = Watch( fs );
Show( fs );
//fs = {"0 is smaller than 1", "00five-oh.txt", "05 Messages.xls", "0meansinfinity.txt", "Hello World.txt"};
Oh, and Watch() behaves the same way in JMP 18.0.1.  I ran the test above in 17.2.
Level XIII
Besides watch in the GUI of the debugger, there is a watch() command:
I just checked some files with 0s with JMP v18.2.1:
seems that it's not the 0s, but a line break which causes the issue - after adding another file:
I'm having no such issues (using JMP18 though). Is the specific reason for using Watch() instead of Show() for example?
folderPath = "$DOCUMENTS";
fd = Files In Directory(folderPath, 1, 1);
show(fd);
I just ran the following example in JMP 17.2 running under Windows11 and had no issues with files with names starting with numbers
names default to here(1);
folderPath = "C:\Users\Jim\Documents\Discussion Groups";
{"0123mike_s.xlsx", "34Yass_Sample_Row6.xlsx", "Chris_Liu", "ConfidenceOwl94",
"mann", "Yass_Sample_Row5.xlsx"}
Correction.  Seems to be leading zeroes, for example "05 Messages.xls" in the file name that cause an issue in what gets returned in the Watch window.
w = Watch( fs );
Show( fs );
w = Watch( fs );
Show( fs );
I changed my file names where one file starts with "01 23mike_s.xlsx".
Running in JMP 17.2 I have no issue in my watch window
Level XIII
