dileepkr
File selection input box in JMP Application builder
I am creating a JMP application which would open a xlsx workbook, load individual sheets into datatables in background and link the datatables to Graph building JSL script buttons in JMP app.
Is there a way to create a file selection input box in JMP Application builder, where in user can browse and select the xlsx workbook from the app?
cwillden
Re: File selection input box in JMP Application builder
Definitely.  Just create a button box and give it a script that does a pick file. Here, I just have a button box and an empty text box named "file_path_text".  For the button box script, I just type in "On Select".
GUI.pngGUI.pngThen in the script window, I define On Select like so:
On Select = expr(
	file_path = Pick File(
		"Select Excel File",
		"$DOCUMENTS",
		{"Excel|xls;xlsx"}
	file_path_text << Set Text(file_path)
When you run it, you should see your selected file printed in the previously empty text box showing the path of your previously selected file.  Use "dt = open(file_path)" to open the selected file when you're script is ready to start working with the selected file.
-- Cameron Willden
cwillden
On Select = expr(
		"$DOCUMENTS",
		{"Excel|xls;xlsx"}
-- Cameron Willden
dileepkr
Thank you so much for the solution!
