FR60
Feature selection in JMP
Hi
I knwow that in JMP Pro for feature selection (I'm not interested in future extraction...) there is the Generalized regression module. Do you know if a similar module is in JMP (standard version) too? If not which is the best method to use with JMP12/13 to reduce the number of predictors to leave only the most important ones?
Thanks  Felice
Re: Feature selection in JMP
Hi Felice,
There is something called Predictor Screening as well in JMP. Here is a link about that option.
http://www.jmp.com/support/help/13/Predictor_Screening.shtml
That can help reduce the number of possible predictors and is in JMP.
Chris Kirchberg, M.S.2
www.jmp.com
9 REPLIES 9
Hello Felice,
There is no Generalized Regression per se in regular JMP.  You do have a few of options though.  If you have highly correlated factors/inputs you can use either Partial Least Squares or Principal Component Analysis.  One other option would be to use Partition Analysis/Decision Trees.  Be sure to use a holdout set to check the predictive capability of any model you build.  For partition analysis look under the red hot spot at the top and select Column Contributions to see which factors are most important.
Hope this helps.
Bill
Hi Felice,
www.jmp.com
FR60
Great
I used it. Very nice.
Felice
You've gotten some good choices from the previous responses (some of which I will repeat), but there are others.
You could just use stepwise regression (a classic). You could use All-Subsets regression. You could use variable clustering. You could use Partition. You could use PLS. You could use PCR (principal component regression). There are graph-based methods: normal plots, pareto plot, bayes plot. You could use predictor screening, etc.
There is a new course being created right now called "JMP Software: Finding Important Predictors" that addresses this issue and covers these techniques, using both JMP and JMP Pro. This two day class will likely be available for delivery at customer locations starting in April. It will be offered as a public class for the first time at the Discovery conference this October in St. Louis.
Dan Obermiller
FR60
Ciao Dan
thank you very much for your msg.
I have some comment to do....
Can it manipulate more than 1K predictors?
Can you give me more details on this tecnique on how to choose important predictors through clustering?
Tipically in our Fab we use it after removing not important predictors (let's consider that generally we have more than thousands predictors and a lot of noisy in our data ....)
We know this but we loose information on predictor meaning and then we prefer don't use it.
I don't know how to do feature selection with graph. Sorry.
This is a great news. I hope that will be available for Italy too. If yes for sure I will follow them.
Rgds.  Felice
My answers to your questions are in blue.
@FR60 wrote:
Ciao Dan
Yes. If you have the memory on your machine to handle large problems. I just ran a simple example with 10,000 observations and 2,000 predictors. Stepwise worked fine.
This would be an approach that is similar to principal components analysis, but instead of you looking at loading plots to see similar variables, JMP will cluster them for you automatically. You can then choose the variable that is most representative of the cluster or even create the "typical" variable for the cluster. This will help you avoid the "redundant information" you often see with many variables.
There are many ways to use Partition, but think of that very first split. The approach needs to determine which split contains the most information. That is a variable selection. You could also use a trick that Dick DeVeaux calls "shaking the tree". Split many, many, times then look at the column contributions of the variables to identify the most important ones. So many ways to use this flexible platform!
Understood. I am not a big fan of PCR for this reason. However, by looking at the loadings of the variables for only the significant principal components, you could possibly identify the original variables that are important. Use those important original variables to start building your model. There is nothing that says you must stick with the principal components.
Nothing to be sorry about. That is why we are creating the class. People are often unaware of these tools.
All of the classes that we create at SAS in the U.S. are available to the international SAS offices, too. If they do not have an instructor that knows the topic, they can request one from another region that does have the skill set. Just ask your local SAS office for the training!
Rgds.  Felice
I hope my comments have been helpful.
Dan
Dan Obermiller
FR60
Ciao Dan
your comments were really welcome and more than helpful. Just last question about clustering.
Once I have n  cluster (some rule on how choose the size of this number ..) how I can identify the most representative variable for each cluster?
Thanks.  Felice
JMP will tell you which variable is most representative of the cluster. It will also determine the proper number of clusters to use.
Dan Obermiller
Peter_Bartell
Level VIII
In addition to all the great suggestions from my colleagues above, if you have a relatively small number of variables I'd also look at the Multivariate Methods -> Multivariate -> Scatterplot Matrix platform. This will give you a nice matrix of pairwise correlations that may exist among the variables and this can be valuable in trying to discover correlations that might exist within the predictor set. These correlations don't play nice with some regression procedures such as ordinary least squares regression (called Standard Least Squares in JMP). If you go down the standard least squares path, make sure to check the variance inflation factors in the parameter estimates table for indications of predictor correlations that may be present.
