Extreme-Value Parameter Estimates
Not sure how Extreme-Value Parameter Estimates compare to  alpha/beta estimates used in the Weibull Parameter Estimates for days to failure plots.
Understand beta of >1 means in Weibull indicates the device will continue to failure over-time, is the Extreme-Value Estimates just a transform of the Weibull Analysis?
Thanks,
Charles
JMP 17
Re: Extreme-Value Parameter Estimates
Mark,
Thanks for the info..  Went back and re-read Bill Meeker book. Think I will stick with Weibull and LogNormal for a device that "gracefully" degrades over time.  Appears Extreme Value is better for early life failures with increasing hf.
Thanks,
Charles
The Weibull distribution cumulative distribution function is related to the Smallest Extreme Value distribution CDF:
(JMP Training course)
The SEV distribution:
The Weibull CDF above can be transformed from a location-scale parameterization to a scale-shape parameterization:
The interpretation of the shape parameter is specifically:
I am not sure if this information is helpful. Continue to ask questions if it is still not clear.
Mark,
Thanks,
Charles
