See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Extract number adjacent to String
AprioriFish3134
Hi, can anybody help me to extract numbers adjacent to strings?
I have column1 shown below, and expect to extract numbers adjacent to "HFA" (column2).
I tried the following JSL, but could not get column2 that I expect
Num( Regex( :Column 1, "(\d\d\d)HFA | HFA(\d\d\d)", "\1" ) )
column1column2
400HFA isa300400
isa300 HFA400400
Thank you for considering the question.
ngambles
Re: Extract number adjacent to String
Given the small example set, the following formula works:
Num( Regex( :column1, "(\d*)HFA(\d*)", "\1\2" ) )
This solution will run into problems if you have instances like "400HFA300".  It will return 400300.
ngambles
Hi Ngambels,
Thank you very much for your help. It resolved the issue.
I did try
"(\d*)HFA(\d*)"
but apparently I missed (I did not know I can and must use both \1 and \2)
"\1\2"
I learned new things from you and through this discussion.
Once again, thank you very much!
If for some reason there is a need to tackle the issue @ngambles mentioned, one fairly simple way would be to use Regex Match instead of Regex
a = "400HFA isa300";
b = "isa300 HFA400";
c = "400HFA300";
d = "400HF300";
rgx_pattern = "(\d*)(?:HFA)(\d*)";
show(Regex Match(a, rgx_pattern));
show(Regex Match(b, rgx_pattern));
show(Regex Match(c, rgx_pattern));
show(Regex Match(d, rgx_pattern));
Regex Match will though require some extra checks as it returns a list of groups captured.
Thanks @AprioriFish3134  for pointing out the original issue (no \2), and @ngambles  for a good solution.
If you need even more levels of nested parens, or the sequential parens in your example, just count the open-parens from left-to-right to discover the back reference number. The back reference for unused alternatives is an empty string.
Regex( "abac", "(((a)|(b)|(c))(c))+", "1=\1 2=\2 3=\3 4=\4 5=\5 6=\6" )
"1=ac 2=a 3=a 4= 5= 6=c"
One thing that might not be obvious: the back reference can also be used in the pattern. This could be useful for making sure a leading and trailing quotation mark or apostrophe are used consistently:
Write( Regex(
	"before 'a \!"b\!" c' after", // before 'a "b" c' after
	"(\!"|')(.*?)\1", // ("|')(.*?)\1
	"\2"
a "b" c
(The \!" escape puts a quotation mark inside the strings; the comment shows the text of the string.) In this example, \1 group can match either " or ' and \2 matches all of the text up to another occurrence of \1.
Use some comments if you write regex like that! The next maintainer will appreciate it.
Good place to practice and test regex is https://regex101.com/ .
Those comments with JMP escape characters removed were very helpful, I have to start adding those when I write more complicated regex patterns (Regex issue with escaped characters )
HI @jthi
Thank you very much for your alternative solution to the issue, and also for the link on regex.
Hi @Craige_Hales ,
Thank you very much for enriching the discussion.
In fact I first learned about JMP's regex from your old article !
https://community.jmp.com/t5/Uncharted/Regex/ba-p/21008
