SpannerHead
Expression Not Evaluating.
Always mystified by how to use Eval Expr correctly.  I have this pop up that asks for a wildcard column name selection and assigns it as "Divider"
nw = New Window( "Does the Data Contain Experimental Cells?",
	<<Modal,
	V List Box(
		Align( "right" ),
		H List Box(
			Panel Box( "Dividing Column", clb = Filter Col Selector( dt, all ) ),
			Panel Box( "Select Cell Identification Column",
				Lineup Box( N Col( 2 ), Spacing( 5 ),
					Button Box( "Divider", clbY << Append( clb << Get Selected ) ),
					clbY = Col List Box( MinItems( 1 ), MaxItems( 1 ), nlines( 1 ) ),
					Button Box( "Remove",
						clbY << Remove Selected;
						clbEffects << Remove Selected;
		H List Box(
			Button Box( "OK", yVars = clby << Get Items( "Column Reference" ) ),
			Button Box( "Cancel" )
Try( Divider = yVars[1] );
I then try to evaluate the object in a column formula and whatever combination of Eval(Eval Expr( I use, nothing seems to work.
If( N Items( yVars ) == 0,
	Data Table( "HIRP" ) << New Column( "Average Active Power",
		Numeric,
		"Continuous",
		Format( "Best", 12 ),
		Formula(
			If(
				:Heater == "Reader", Col Mean( :HL_R_HEAT, :Heater ),
				Contains( :Heater, "Writer" ),
					Col Mean( :HL_W_HEAT, :Heater )
	Eval(Eval Expr(Data Table( "HIRP" ) << New Column( "Average Active Power",
		Numeric,
		"Continuous",
		Formula(
			If(
				:Heater == "Reader", Col Mean( :HL_R_HEAT, :Heater, As Column(Expr(Divider)) ),
					Col Mean( :HL_W_HEAT, :Heater, :HD_NUM, As Column(Expr(Divider)) )
Slán
SpannerHead
Re: Expression Not Evaluating.
Change
To
Expr(NameExpr(As Column(dt, Divider)))
Name Expr() isn't necessary but you will end up with "nicer looking" formulas when you use that.
dt = open("$SAMPLE_DATA/Big Class.jmp");
div = "weight";
Eval(EvalExpr(
	dt << New Column("C", Numeric, Continuous, Formula(
		:Height / Expr(NameExpr(AsColumn(dt, div)))
Also, you can test your expression evaluations by just running the EvalExpr part instead of the whole Eval(EvalExpr(...
SpannerHead
Needed a small tweak but worked, Thanks
		Numeric,
		"Continuous",
		Formula(
			If(
		Numeric,
		"Continuous",
		Formula(
			If(
				:Heater == "Reader", Col Mean( :HL_R_HEAT, :Heater, Expr(NameExpr(As Column( Divider))) ),
					Col Mean( :HL_W_HEAT, :Heater, :HD_NUM, Expr(NameExpr(As Column( Divider))) )
Slán
SpannerHead
Change
To
div = "weight";
Eval(EvalExpr(
SpannerHead
		Numeric,
		"Continuous",
		Formula(
			If(
		Numeric,
		"Continuous",
		Formula(
			If(
Slán
SpannerHead
SpannerHead
Jarmo
I have something that works now but I don't understand why it works.  Is there somewhere that gives a clear description of how the evaluation methodology should be employed?  Hoping to spend less time on here searching for answers.
Slán
SpannerHead
