NeF
NeF
Exporting data from jmp to excel without excluded rows
Is there any add-in for jmp that helps exporting data to excl without exclueded rows?
Thanks,
Ne
Re: Exporting data from jmp to excel without excluded rows
If you just use
File==>Save As
and then navigate to the folder you want to save the data table to and specify to save it as an Excel Workbook, the table will be saved without eliminating and Excluded rows.
Is this what you were asking, or is there something I am missing.....
Oops.....I misread the question......Dan below has an answer that works.....delete the excluded rows, but, you can also easily subset the data table, by selecting the non excluded rows, and then save that data table to Excel
NeF
NeF
Dear txnelson,
Thanks for your kind reply.
Dan's reply and yours as well (the second one :) )  helped me alot.
Best,
NeF
If you want the Excel table WITHOUT the excluded rows, it is would be easiest to select the excluded rows (you can do that easily by clicking on the Excluded Rows number in the Row Panel), delete them, and use File > Save As and choose the Excel format.
Dan Obermiller
NeF
NeF
Dear Dan,
Thanks!
NeF
