Export raw data from marginal model plots
Hi
JMP18.02 PRO student version
i have conducted support vector regression with 9 variables.
at the report i have the marginal plot that its apearance is not good enough for article.
I whould to export the raw data (numbers of x and y from the model) to excell (or other) in order to run loess and edit other things.
Is it possible?
Idan
Re: Export raw data from marginal model plots
Have you tried modifying the graph in JMP?
Usually you can find "Save Predicteds" and "Save Prediction Formula" from red triangle menus. These should get you the data to your table.
1. I've tried to modify its not good enough for me
2. the Save Predicteds returns the y prediction values and its not what I need.
what I am looking forare  the x and y numbers behind the marginal model plots of the support vector machine model.
