New to JMP? Join us Sept. 23-24 for the Early User Edition of Discovery Summit, tailor-made for new users. Register now for free!
Use World Cup data to build models, explore spatial relationships, and create informative visualizations in JMP. Register. July 17, 2 pm US Eastern Time.
Your voice matters! Tell us how you prefer to receive JMP updates, so we can tailor our communication to your needs. Take short survey.
pickdir=pick directory();//pick where you want your file to go
dt=current data table();
//clear selections - if the selected column is left it will only bring that column into the journal
dt<<clear select();
dt << Clear Column Selection();
journaltext = (Window( dt )) << getjournal;
journalbox = Journal Box( journaltext );
image = journalbox << getpicture;
//nw=New Window( "image", image );//opening the journal so you can see the appearance-this line isnt needed
image<< Save Image( saveloc=pickdir||"Journalgraph.png", "png" );
open(saveloc);
Here's a generic JSL that will work with any table by sending it over to a journal and saving as you've requested. I've added a prompt at the start so you can pick where you want the file to save.
nw = New Window( "data table journal",<<journal,
placeholder_VLB=v list box());
placeholder_VLB<<append(data table box(dt));
image=nw<<get picture;
open(saveloc);
Clever script! Only remaining issue is that the resulting Journal loses all it's formatting from the original table. The original had a lot of colouration indicating pass or fail.
dt<<clear select();
open(saveloc);
You can also << get as report + << get picture (<< Get As Report can be helpful in many other places also not just here)
dt = open("$SAMPLE_DATA/Big Class.jmp");
r = dt << Get As Report;
img = r << Get Picture;
img << Save Image("$TEMP/pic.png", "png");
Open("$TEMP/pic.png");
If you wish to access the table box which << get as report does create, you can use << Child on the created display box (it is a border box on highest level)
r = dt << Get As Report);
tb = r << child;
tb << Set Title Font Style("Bold");
img = tb << Get Picture;
Write();
or data table box (this won't support coloring)
r = Data Table Box(dt);
videodata.push(data[i]);
catch(e){
/* Re compile html */
/* Adding Translation flag */
if (tr_obj.length > 0) {
try {
} catch (e) {
} else {
try {
tr_para.appendChild(tr_fTag);
else {
} else {
} catch (e) {
} else {
// syncList.remove(value);
if (index > -1) {
}else {
if (value == '881146' && "ForumTopicPage" == "TkbArticlePage") {
/* V1.1 Remove from UI */
var sub_L = "";
if(value == '881146') {
}else{
sub_L = newSub.innerHTML;
else{
} else {
try{
catch(e){
if (value == '881146') {
if(subTkbElement){
try {
if(subElement) {
subElement.innerText = sub_L;
} catch (e) {
else {
try {
} catch (e) {
else {
try{
} else {
} else {
catch(e){
} else {
try {
else{
} catch (e) {
// Label translation
if (!labelEle) {
if (labelEle) {
if (listContains) {
trLabels = [];
trLabelsHtml = "";
/* try{
for(var j=0;j,';
trLabelsHtml = trLabelsHtml+'
