KL
KL
Excel VBA to automate JMP
Hi Folks, i am trying to run JMP time series analysis from excel VBA.
below is the codes
Sub LData()
Dim myjmp As JMP.Application
Dim jmp_doc As JMP.Document
Dim jmp_BL As JMP.DataTable
Dim jmp_dt As JMP.DataTable
Dim jmp_dtFinal As JMP.DataTable
Dim jmpstr As String
Set myjmp = CreateObject("JMP.Application")
myjmp.Visible = True
Set jmp_doc = myjmp.OpenDocument("C:\Data_Doc1.xlsx")
Set jmp_BL = jmp_doc.GetDataTable
Dim TS As JMP.TimeSeries
Set TS = jmp_doc.CreateTimeSeries()
Dim Cont As JMP.timeSeriesConstraintConstants
Winter = tsConstraintZeroToOne
Dim Modd As JMP.timeSeriesModelConstants
Modd = tsModelWinters
TS.LaunchAddYSeries ("Sell")
TS.LaunchAddNumAutoCorrLags (25)
TS.Launch
Call TS.SmoothingModel(Modd, Winters)
End sub
it gives me a error message in JMP
unknown operation
Seasonal model needs numeric argument: periods per season
i did not have the option to key in periods per season when i was doing up Call.TS.SmoothingModel(Modd,Winters)
need your help to enlighten me what i am missing
Thanks a lot in advance.
Cheers.
Kenny
Re: Excel VBA to automate JMP
Unfortunately, it looks like the automation method for Smoothing Model is out of date with the options in Time Series.  I will contact Tech Support to let them know that the issue should be entered to correct this in a future version of the product.  The only workaround that I am aware of for this case is to use the automation "RunCommand" method to submit JSL directly to JMP to do the analysis.  So, you could do something like below (using the sample data "Raleigh Temps")
Dim DocX As JMP.Document
DocX = myJMP.OpenDocument("c:\program files\sas\jmppro\14\samples\data\Time Series\Raleigh Temps.jmp")
myJMP.RunCommand("Time Series(X( :Month Number ),Y( :Temperature ),Winters Method( 48, Zero to One, Prediction Interval( 0.8 ) ))")
Can you produce the analysis that you desire using JMP's Time Series dialogs?  If so, can you post the script from a successful analysis here (report Red Triangle->Save Script->To Script Window).
Thanks,
Brian Corcoran
JMP Development
KL
KL
Time Series(
Y( :Sell ),
Number of Forecast Periods( 12 ),
Winters Method( 48, Zero to One, Confidence Intervals( 0.8 ) ),
Dispatch(
{"Model Comparison"},
"2",
ScaleBox,
{Add Ref Line( 0, Dashed, "Black" )}
Dispatch(
"8",
ScaleBox,
Dispatch(
"3",
ScaleBox,
{Add Ref Line( 70, Solid, "Blue" ), Show Major Grid( 1 )}
Dispatch(
"4",
ScaleBox,
Dispatch(
"5",
ScaleBox,
thanks a lot for the help
KL
KL
no problem, thanks a lot for your help.
