I want to import an excel sheet to a JMP table. The excel file will have multiple sheets. The user should be able to select a sheet of interest. When imported, the user should be able to select the header row and the number of columns of interest. All the rows in that sheet in to be imported. JMP PRO 14.3, JMP PRO 16.2
