See how to use to use Text Explorer to glean valuable information from text data at April 25 webinar.
Eval & Expr
RosDima
Hi All,
I am trying to use next code:
x = summDt:Slot[1];
y = summDt:Slot[2];
z = summDt:Slot[3];
t = summDt:Slot[4];
New Window( "EtchRate By (Slot) - Bivariate",
V List Box(
Bivariate(
Y( :Name( "Mean(ER)" ) ),
X( :Radius ),
Fit Each Value( {Line Color( {213, 72, 87} )} ),
Where( :Slot == eval(x)),
Dispatch( {}, "Bivar Plot", FrameBox, {Marker Size( 4 )} )
Bivariate(
X( :Radius ),
Where( :Slot== eval(y) ),
Bivariate(
X( :Radius ),
Where(:Slot==eval(z) ),
Bivariate(
X( :Radius ),
Where(:Slot== eval(t) ),
But have issue with Eval function, how can I use it to show specific values from DT? I want to use Slot number without knowing it before each use, I know that I have 4 different Slot numbers and for each one need to build graph.
Thanks.
ms
Super User (Alumni) ms
Re: Eval & Expr
It should work without Eval(). Make sure that dt is the current data table or send the Bivariate() command to dt explicitly.
Example:
dtsum = dt << summary(Group(sex));
x = dtsum:sex[1];
y = dtsum:sex[2];
New Window("Height By Weight - Bivariate",
    V List Box(
        dt << Bivariate(Y(:height), X(:weight), Where(:sex == x)),
        dt << Bivariate(Y(:height), X(:weight), Where(:sex == y))
//Alternative using By(), if all "slots" are to be graphed
    V List Box(dt << Bivariate(Y(:height), X(:weight), By(:sex)))
ms
Re: Eval & Expr
Example:
x = dtsum:sex[1];
y = dtsum:sex[2];
    V List Box(
RosDima
Re: Eval & Expr
Instead of number it I am getting :sex==x, my goal to get :sex==Expr(x) ==> :sex==1, in case x=1
Thanks
Re: Eval & Expr
Please can you give more details about what your final report should look like? Can you explain why the answer MS gave is not suitable? Have you tried using the Dashboard builder with local data filters on each graph?
No recommendations found
