Ressel
Error message when closing home made application via button ("Unresolved Column at row 1")
How can I make this error message here go away?
It appears when I close table and window via the "Close Window" button after I have first drawn a graph. I copied in the script below, but to run it one would have to have open an adequate data table (see attached example). This, and only this table, should be open when running the script. This script is an attempt at having a little desktop stability calculator (very dirty, reasonably quick) / helper when writing reports, assessing product shelf-life etc.. It lets the user apply our normalized stability data (where t=0 corresponds with 100%rel.) to hypothetical starting concentrations of any quality parameter (as far as it is numeric) and quickly switch between settings and parameters. I made it thus far, but this error message is driving me nuts. (Also, can I show this on the next In-Person Nordics User Group: 05 October 2022 ?)
Delete Symbols();
dt << Clear Row States;
dt << Clear Select;		// avoids accidentally including columns in colList
// alpha level for bivariate plot
alpha = 0.1;
// get lists for model selection
Batch = Associative Array( dt:Batch ) << Get Keys; // direct column reference
For( i = 1, i <= N Row( dt ), i++, // find all rel% columns
	For( j = 1, j <= N Col( dt ), j++,
		If( Column( j )[i] == 0,
			For( k = 1, k <= N Col( dt ), k++,
				If( Column( k )[i] == 100,
					Column( k ) << Set Selected( 1 )
colList = dt << Get Selected Columns;
// length of column list box
nItems = N Items( colList );
// radio box argument
rb1_expr = Expr(
	one_rb = rb1 << Get Selected;
	dt << Select Where( (dt:Batch == one_rb) ); // direct column reference
	dt << Invert Row Selection;
	dt << Hide and Exclude;
	dt << Invert Row Selection );
// "draw graph" button & column list selection arguments
action_expr = Expr(
	vlb << Delete; // delete existing vlb
	yColAbs = Eval(
		Eval Expr(
			dt << New Column( one_rb || " / " || " / " || "start level = " || Char( startLevel ) || " for " || Char( yColRel ),
			formula( Expr(startLevel) / Expr(100) * (As Column( Expr( yColRel ) ) ) )
	pb << Append( // append new vlb with fresh graph
		vlb = V List Box(
			biv = Bivariate(
				Y( yColAbs ), // is this the culprit?
				X( dt:Time ), // direct column reference
				Fit Line(
					{Confid Curves Fit( 1 ),
					Confid Curves Indiv( 1 ),
					Confid Shaded Fit( 1 ),
					Confid Shaded Indiv( 1 ),
					Line Color( {230, 159, 0} )},
					{Set α Level( 0.1 )}
				Automatic Recalc( 1 ),
					// note reference to one_rb below in use for changing y axis label
					Dispatch( {}, one_rb, TextEditBox, {Set Text( "QC parameter value" )} ),
					Dispatch( {}, "timepoint 1", TextEditBox, {Set Text( "Time [months]" )} ),
					Dispatch( {}, "Linear Fit", OutlineBox, {Close( 1 )} )
// model selection window with radio buttons & colum list box
nw = New Window( "Model selection",
	Show Menu( 0 ),
	Show Toolbars( 1 ), // to have access to cross hair
	Border Box( Top( 0 ), Bottom( 20 ), Left( 20 ), Right( 10 ),
		H List Box(
			Panel Box( "Batch",
				rb1 = Radio Box(
					Eval List( Batch ),
					rb1_expr
			Panel Box( "QC parameter (y-axis)",
				stabDat = Col List Box(
					Max Selected( 1 ),
					Width( 250 ),
					N Lines( nItems ),
					On Change(
						yColRel = Column( dt, (stabDat << Get Selected) );
						If(	Is Empty( startLevel ),
							//then
							Empty(),
							//else
							action_expr
			stabDat << Append( colList );
			Panel Box( "Action",
				V List Box(
					H List Box (
						neb = Number Edit Box( Empty(), 7, << Set Function(
							startLevel = neb << Get;
							If(	Is Empty( yColRel ),
							//then
							Empty(),
							//else
							action_expr
						Spacer Box( Size( 5, 0 ) ),
						Text Box( "Enter start level" )
					Spacer Box( Size( 0, 10 ) ),
					Button Box( "Draw graph",
						If( ( Is Empty( startLevel ) + Is Empty( yColRel )) > 0,
							// then
							New Window( "Message", modal,
								V List Box(
									Text Box( "QC parameter selection and/or start level missing!" ),
									Spacer Box( size( 0, 10 ) )
							// else
							action_expr
					Button Box ( "Close Window",
						If( !Is Empty( PF ), PF << Close Window);
						nw << Close Window;
						Close(dt, no save)
			pb = Panel Box( "Model",
				vlb = V List Box () // space for model graph
// making the initially selected buttons active in row selection
Re: Error message when closing home made application via button ("Unresolved Column at row 1")
I think you action_expr is getting triggered when you close the window and then it will get all messed up. I'm not exactly sure why this happens, but the Col List Box isn't getting destroyed fast enough. As a workaroud you could maybe move the data table closing to On Close() and remove it from "Close Window" button.
Add this as last line
nw << On close(Close(dt, no save));
and change the button to
Button Box("Close Window",
	If(!Is Empty(PF),
		PF << Close Window
	nw << Close Window;
Ressel
Just in case this is of any interest, the error message was caused by the use of "On Change" rather than "Set Function"  in connection with the Column List Box. The script (or at least a modified version of the one posted here) kept throwing error messages when not quit using the "Close Window" button but the eXit button in the top right corner of the window. This happened after I had added a few lines to make sure the data table is closed regardles of how the window is exited. I suspect that the "On Change" is triggered ... somewhow ...
Old
					Max Selected( 1 ),
					Width( 250 ),
					N Lines( nItems ),
					On Change(   // not working so well for this application
							//then
							Empty(),
							//else
							action_expr
New
					Max Selected( 1 ),
					Width( 250 ),
					N Lines( nItems ),
					<< Set Function(   // no more error messages
							//then
							Empty(),
							//else
							action_expr
	If(!Is Empty(PF),
		PF << Close Window
	nw << Close Window;
Ressel
Old
					Max Selected( 1 ),
					Width( 250 ),
					N Lines( nItems ),
							//then
							Empty(),
							//else
							action_expr
New
					Max Selected( 1 ),
					Width( 250 ),
					N Lines( nItems ),
							//then
							Empty(),
							//else
							action_expr
A quick and dirty way to handle the issue would be to change the Close Window paragraph to ignor errors
Button Box( "Close Window",
		Try( PF << Close Window )
	Try( nw << Close Window );
	Try( Close( dt, no save ) );
Ressel
Thank you! As always, greatly apprciated, but still throwing an error message. @jthi's solution worked though.
Level XIII
In case anyone has a similar problem with an application generated in Application Builder.
For applications, the on close() command can be sent via
(thisModuleInstance << Get Box) << on close(...)
