WesOdom
Error While Trying to Impute Missing Data
Just went into the tool for exploring missing values and after it lists all the missing values I clicked "Multivariate Normal Imputation," then clicked yes on shrinkage, and it says there are no missing values... despite listing all the missing values. See image for seemingly conflicting information.
Re: Error While Trying to Impute Missing Data
Most likely one of your columns is actually a character string. That is the message you see when you try to impute with a character string column. Check for that first.
Dan Obermiller
