bzanos
Error Message "Please select the rows to be deleted"
when I am running JSL script, there is message in the log,  "Please select the rows to be deleted".
But the script is still running. I could identify anything error in my code.
Does anyone know what will cause this error?
dt1 << Select Where(:Tcount > 40);
dt1 << Delete Rows;
Re: Error Message "Please select the rows to be deleted"
Try( dt1 << Delete Rows );
or
If( dt << get selected rows > 0,
     dt1 << Delete Rows;
How many rows are selected after running the first line?
My initial guess is that there are no rows selected because there are no values of Tcount greater than 40.
bzanos
Markbailey, Jim,
There is no rows selected as there are no values of Tcount greater than 40.
 Is there a way to avoid see this error?
or
     dt1 << Delete Rows;
bzanos
Thanks Jim
